| Bookshelf Home | Contents | Index | Search | PDF | ![]() ![]() |
Siebel Wireless Administration Guide For Financial Services >
Configuring Siebel Wireless
The user interface and behavior of many aspects of the Siebel Wireless applications can be configured to address your particular business needs using the same tool set (Siebel Tools) and other infrastructure as the rest of the Siebel eBusiness Applications suite.
This chapter focuses on three main areas in which the configuration of Siebel Wireless applications can be modified:
- The Siebel Wireless application server configuration files.
- The Siebel Wireless objects defined in Siebel Tools.
- The Siebel Wireless template files (including wireless Web templates and XSL stylesheets).
This chapter focuses specifically on configuration considerations for the Siebel Wireless thin client applications, and references other documents on the Siebel Bookshelf for more general information on configuring Siebel eBusiness applications.
Siebel Wireless Administration Guide For Financial Services Published: 18 April 2003 |
