| Bookshelf Home | Contents | Index | Search | PDF | ![]() ![]() |
Siebel Wireless Administration Guide For Financial Services > Configuring Siebel Wireless >
Configuring with Server Configuration Files
The following server configuration files are created for the various Siebel Wireless applications during the installation of Siebel eBusiness Applications. These files can be found in the
\siebsrvr\BIN\lang directory for the language installed (such as ENU for English):
- finswpsales.cfg for Sales
- finswpserv.cfg for Service
- wpbanking.cfg for Banking and Brokerage
These server configuration files should be used to define installation-related preferences for Siebel Wireless applications such as enabling the Siebel Wireless Auto Login feature, integrating Siebel Wireless applications with directory servers, enabling Wireless support for the XML Web Interface and HTML wireless browsers.
Additionally, these configuration files can be used to perform such optional configurations as altering the number of records returned by lists in Siebel Wireless, and turning off case sensitivity for Siebel Wireless applications.
Note that the configuration changes discussed in this section must be made to each of the individual server configuration files described above for Siebel Wireless applications for which the new configuration is desired. The Siebel server must be stopped and started after these configuration changes are made to force the new configuration into effect.
Siebel Wireless Administration Guide For Financial Services Published: 18 April 2003 |
