| Bookshelf Home | Contents | Index | Search | PDF | ![]() ![]() |
Siebel Wireless Administration Guide For Financial Services > Configuring Siebel Wireless > Configuring with Server Configuration Files >
Altering the Number of Records Returned by Lists
By default, Siebel Wireless applications return three records with each list. For example, the list of employees accessible from the Siebel Sales Wireless application displays the first three employees the first time it is accessed, and it displays the next three employees each time the More link is selected.
You can alter the number of records returned by lists by setting an entry in the SWE section of the relevant Wireless Server configuration file as follows:
[SWE]
NumberOfListRows = <Number Desired>Note that some wireless browsers impose limitations on the amount of data that can be retrieved with any one request. Increasing the number of rows returned may cause the requests coming from the Siebel Server to exceed the data request size limitations imposed by these wireless browsers. Therefore, you should test the ability of the wireless browsers that will be used to access Siebel Wireless applications to handle the additional data returned from the Siebel Server once this parameter is changed to make sure that your changes do not produce a "Digest Too Large" or similar error.
Siebel Wireless Administration Guide For Financial Services Published: 18 April 2003 |
