Table 18. Activity Details
Field
Contains
Editable?
Description
The description for the activity
The field name links to the Description view where you can edit the text.
Planned Start
The date and time the activity is scheduled to start
The field name links to the Planned Start view where you can edit the date and time.
Company
Name of the company associated with the activity
The field name links to the Pick Company view where you can select a different company. The field data links to the Company detail view.
Type
The type of activity, such as meeting, inquiry, and so forth
The field name links to the Pick Type view, where you can select the type of activity.
Status
The status of the activity, such as started, in progress, and so forth
The field name links to the Status view, where you can select the status of the activity.
Due Date
The date the activity is scheduled to finish
N/A
Priority
The priority of the activity, such as ASAP, high, medium, or low
The field name links to the Priority view, where you can select the priority of the activity.
Comments
Text comments about the company
The field name links to the Comments view where you can edit the information.
Assigned To
Employee assigned to this activity
N/A
