| Bookshelf Home | Contents | Index | Search | PDF | ![]() ![]() |
Siebel Wireless Administration Guide For Financial Services > Using Wireless eFinance and eInsurance >
Calendar
Use the Calendar view to see your appointments for today or any other day, to modify information, or to add or delete an appointment.
When you select Calendar from the Main Menu, your device displays today's appointments.
You can drill down to see details about any activity displayed on the screen. You can edit activity information from the Activity view.
To display activity details
- Scroll to the activity for which you want to see details.
- Press the soft key to link to the selected activity.
The Activity view opens and displays details for the selected activity.
To add a new calendar appointment
- Scroll to the bottom of the view and select the New link.
- In the New Activity view, enter the activity type and the start date and time.
- Enter the description.
- Click Submit.
- In the detail record, add company, status, priority, and comments.
Siebel Wireless Administration Guide For Financial Services Published: 18 April 2003 |
