| Bookshelf Home | Contents | Index | Search | PDF | ![]() ![]() |
Siebel Wireless Administration Guide For Financial Services > Using Wireless eFinance and eInsurance >
Main Menu
When you complete the login process, the application displays either the Wireless Sales Main Menu or the Wireless Service Main Menu.
Figure 3 shows an example of the Wireless Sales Main Menu.
Figure 4 shows an example of the Wireless Service Main Menu.
The screens shown in this document may or may not reflect the actual screens on a particular device. In many cases, your device will have a different convention for showing links, for indicating a soft key, for linking to another screen or to Siebel data, or for some other feature.
For example, some devices use [square brackets] to indicate linking screen entries (field names, field data, links); other devices use underlines to show the same functionality. Similarly, some devices use OK as the name of the soft key that activates a selected action. Other devices use different soft key names.
Siebel Wireless Administration Guide For Financial Services Published: 18 April 2003 |
