Siebel Hospitality Guide > Generating Event Checks > Process of Generating Event Checks > Splitting Event ChecksTo generate multiple event checks for a single function, you can split (or divide) the event check that includes that function. After you split an event check, you can split both of the two resulting event checks. To split an event check, you must select parent line items, and not child line items. When you select a parent item, all of the associated child items are automatically included in your selection. Taxes and service charges are automatically recalculated for the line items in the event checks that result when you split an event check. NOTE: You cannot split meeting packages, meeting package types, accommodations, or function line items from a package event check. This task is a step in Process of Generating Event Checks.
| Siebel Hospitality Guide | Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
