Siebel Database Upgrade Guide for DB2 for z/OS > Planning a Siebel Database Upgrade > About Using the DSNTIAUL Utility > About Applying the DSNTIAUL PatchThe DSNTIAUL patch, @@TIAUL USERMOD, is packaged as an SMP/E format USERMOD. The patch is a MACUPD (macro update) because DSNTIAUL is delivered as a macro and not as a source object. The @@TIAUL USERMOD updates the DSNTIAUL assembler source code so that nonzero return codes generated solely by the selective SELECT statements are suppressed. The USERMOD is generic in that it applies to known fix levels of the DSNTIAUL utility. NOTE: It is recommended that a DB2 systems programmer who has knowledge of SMP/E and your maintenance process applies the patch. To apply the patch, copy the @@TIAUL USERMOD code, listed in The @@TIAUL USERMOD Patch, and apply it to the SMP/E DB2 target zone on z/OS. You can apply the patch using various methods, for example:
Ask your z/OS system administrator for the most appropriate method to use to apply the @@TIAUL USERMOD at your site. The @@TIAUL USERMOD PatchThis topic lists the @@TIAUL USERMOD for IBM DB2 UDB for z/OS Version 8. Before copying the following code and applying the USERMOD, change the modification control statements to reflect the applicable maintenance level of the existing DSNTIAUL utility; comments in the @@TIAUL USERMOD provide specific instructions. NOTE: Sequence numbers must start in column 72. ++ USERMOD (@@TIAUL) REWORK(2010007) THIS USERMOD WILL CAUSE ONE SECTION OF CODE TO BE BYPASSED. THIS SECTION SETS RETURN CODE 4 IN THE CASE OF A SELECT NOT THE CHANGE ALSO INCLUDES AN "ORACLE81" EYECATCHER. NOTE: MACRO FMID RMID SYSLIB DISTLIB DATE */ . |
| Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
