Siebel VB Language Reference > Using Siebel VB > About ExpressionsAn expression is a collection of two or more terms that perform a mathematical or logical operation. The terms are typically variables or functions that you use with an operator to evaluate to a string or numeric result. You can use an expression to perform a calculation, manipulate a variable, or concatenate a string. Siebel VB evaluates an expression according to precedence order. You can use parentheses to override the default precedence order. The following operators are listed in order of highest precedence to lowest precedence: Numeric OperatorsTable 7 describes numeric operators.
String OperatorsTable 8 describes string operators. Comparison OperatorsTable 9 describes comparison operators. For a number, Siebel VB increases the operands to the least common type: For a string, the comparison is case-sensitive and is according to the collating sequence that the language specifies in the Microsoft Windows Control Panel. The result is 0 for FALSE and negative 1 for TRUE. Logical OperatorsTable 10 describes logical operators. Siebel VB performs a bitwise operation for each operator.
| Siebel VB Language Reference | Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
