Understanding Global Payroll for Australia
This chapter discusses:
Click to jump to parent topicGlobal Payroll for Australia
Global Payroll for Australia is a country extension of the core Global Payroll application. It provides the payroll rules, elements, and absence processes needed to run an Australian payroll.
Click to jump to parent topicGlobal Payroll for Australia Business Processes
Global Payroll for Australia supports the following business processes:
Note. If you elect to use the delivered rules for Global Payroll for Australia, use only the employment instance in Human Resources.
See Also
Managing Taxation Processing
Reporting State Payroll Tax Liabilities
Administering Superannuation
Running Banking and Recipient Processes
Printing and Viewing Payslips
Using the General Ledger Interface
Defining Absence Rules
Understanding Termination Payment Management
Monitoring Salary Packaging Expenditure
Managing End of Year Reporting
Click to jump to parent topicDelivered Elements
Global Payroll defines each business process for Australia in terms of delivered elements and rules. Some of these elements and rules are specifically designed to meet legislative requirements. Others support common or customary payroll practices.
Click to jump to top of pageClick to jump to parent topicCreation of Delivered Elements
All of the elements and rules delivered as part of your country extension were created using the core application—the same application that you use both to create additional elements or rules, and to configure existing elements delivered as part of the Global Payroll application. Because the tools needed to redefine or create new payroll elements are fully documented in the core application PeopleBook, that information does not appear here. Instead, this PeopleBook briefly reviews the relationship between the core application (which contains the tools that you need to define your own elements and rules) and the country extensions (which contain country-specific rules and elements defined by PeopleSoft).
The core application has the following characteristics:
Country extensions have the following characteristics:
Click to jump to top of pageClick to jump to parent topicElement Ownership and Maintenance
The delivered elements and rules of the Global Payroll country extension can be classified according to whether they are owned and maintained by you or by PeopleSoft. Some elements and rules are maintained exclusively by PeopleSoft and cannot be modified, while others can be configured to meet requirements unique to each organization.
Element Ownership in Global Payroll
There are five categories of element ownership:
PS Delivered/Maintained (PeopleSoft-delivered and maintained)
Elements delivered and maintained on an ongoing basis by PeopleSoft.
PS Delivered/Not Maintained (PeopleSoft-delivered but not maintained)
Elements delivered by PeopleSoft that must be maintained by the organization. This category consists primarily of either customary (or non-statutory) rules and statutory elements that organizations may want to define according to different interpretations of the rules. Although PeopleSoft may occasionally update elements defined as PS Delivered/Not Maintained, you are not required to apply these updates.
Customer Maintained
Elements created and maintained by the organization. PeopleSoft does not deliver rules defined as Customer Maintained.
PS Delivered/Customer Modified (PeopleSoft-delivered and customer-maintained)
Elements that were originally PS Delivered/Maintained elements over which the organization has decided to take control. This change is irreversible.
PS Delivered / Maintained / Secure
Delivered elements that the organization can never modify or control.
Element Ownership in Global Payroll for Australia
Of the five ownership categories listed in the previous section, only PS Delivered/Maintained and PS Delivered/Not Maintained are used to define Australian elements. Although Global Payroll for Australia delivers some elements as PS Delivered/Maintained, most elements are designated PS Delivered/Not Maintained. This enables you to modify, update, and reconfigure the delivered elements to meet needs that are specific to your organization.
Note. In general, Global Payroll for Australia uses the ownership category PS Delivered/Not Maintained unless the modification of an element might interfere with calculations that satisfy legislative requirements. The benefits of this approach are evident if you consider the setup of delivered accumulators. Because balance accumulators (for example, those storing taxable gross on a year-to-date basis) must be set up to comply with the legislative requirement for calculating taxes, Global Payroll for Australia defines them as PS Delivered/Maintained. You cannot modify or directly add new elements to them. However, you can add new elements to these accumulators by using the delivered segment accumulators, which serve as the entry point into the system. They are not maintained by PeopleSoft. When you define a new earning or deduction, you can assign the element to a segment accumulator, and the segment accumulator automatically contributes to the correct balance accumulators.
In the following table of elements supplied with Global Payroll for Australia, the element ownership is PS Delivered/Not Maintained, with exceptions shown in the right-hand column.
Note. The following element types have no exceptions and are therefore not shown in the table: Absence Entitlement, Absence Take, Count, Duration, Date, Element Group, Earning, Generation Control, Historical Data Rule, Process, Rate Code, Rounding Rule, and Writable Array.
Element Type
Exceptions
Accumulators
  • Total Tax for the Period.
  • HELP Earnings - Annualized.
  • Total Earns: Annualized, Leave Loading, Lump Sums A, B, D & E, Lump Sum C Taxable & Non Tax, and Marginal.
  • Period to Date (PTD): Earnings, HELP, Leave Loading, SFSS Amount, Tax Amount, and HELP and SFSS Marginal.
  • Year-to-Date (YTD) Earns - Leave Loading.
Array
  • Payee's Normal Gross Earnings, EE Tax Detail (employee tax detail).
  • Tax Scale: Details & Rates.
Bracket
Australian: FTB Rates, HELP Rates, and SFSS Rates.
Deduction
  • Annualized Tax, HELP Amount.
  • Lump Sum: A, B, C, and E Tax.
  • Marginal Tax, SFSS Amount.
Formula
  • Error: Formula for AR EARN ALL, Retrieving EE Tax Data, Retrieving Tax Rates Dtl & Rates.
  • TAX FM (PIN_NM): All TAX formulas.
  • TER FM (PIN_NM): LSL Termination Calculation, Post 1978 Accrual LSL, Post 1993 Accrual LSL .
Section
Tax Deduction Section, TAX - DED
Variable
  • Balance Group ID, Message Set No for Aust - Batch, Result of Proration Work Day.
  • TAX VR (PIN_NM): All TAX variables except: Balance Group ID, Pay Entity.
  • TER VR (PIN_NM): Lump Sum D Initial Value, Lump Sum D Yearly Value.
Click to jump to parent topicNaming Elements
To understand how delivered payroll elements function in the system, you need to understand their names. The naming convention for PeopleSoft-delivered elements enables you to determine how an element is used, the element type, and even the functional area it serves. Depending on whether the element is a primary element, a component of a primary element, or a supporting element, one of the following naming conventions applies.
Supporting Elements
For supporting elements, such as variables, formulas, dates, durations, and so on, PeopleSoft uses the following naming convention: FFF (or FF) TT NAME.
For example, in the garnishment variable GRN VR PROC STATUS, GRN stands for garnishment, VR stands for variable, and PROC STATUS stands for process status. With a maximum of 30 characters, the element's description (DESCR) field provides details about the element's purpose.
Primary Elements
Primary elements—such as earnings, deductions, absence take, and absence entitlement elements—often do not contain functional area codes or element type codes in their names. This is because primary elements have names, based on Australian terms, that identify their function and element type without the use of additional codes. For example, the name of the earning element PAY IN LIEU clearly identifies the element as an earning—specifically, as payment in lieu of notice.
Additional Information about Elements
Many Australian elements contain abbreviations that provide additional information about their purpose (beyond what the functional area codes and element type codes provide). For example, consider the following duration elements: PSH DR BS PRD D and PSH DR BS PRD Y. The functional area code PSH indicates that these elements are used for Prior Service History elements, and the element type code DR identifies them as duration elements. The abbreviations BS, PRD, and D and Y provide additional information about how each element measures periods of time. The durations are of between-service (BS) periods (PRD) expressed in days (D) and in years (Y). As you become more familiar with the payroll rules created for Australia, these abbreviations enable you to identify the role of each element.
The following table lists the most common abbreviations used in the names of Australian elements.
Abbreviation
Meaning
ACCR
Accrual.
ADDL
Additional.
AL
Annual leave (also ANN).
AMBR
Adjustment accumulator member.
AMT
Amount.
BAL
Balance.
BMBR
Balance accumulator member.
BSD
Based (for example, TIERBSD for tier-based).
CHK
Check.
DTL
Detail.
DYS
Days.
EE
Employee.
EMBR
Entitlement accumulator member.
ENT
Entitlement.
ER
Employer.
ETP
Eligible termination payment.
GRP
Group.
HPH
Hours per hour (entitlement).
HR or HRLY
Hours or hourly.
LIAB
Liability.
LL
Leave loading.
LST
Last.
LUMP[*]
Lump sum [A, B, C, D or E].
MAR
Marginal (tax).
MTH
Month.
NML
Normal.
OVRD
Override.
PD or PRD
Period (or product for PRD).
PRO
Pro rata.
PUB
Public (as in public holiday).
ROLL
Rolling (average).
RT
Rate.
SCL
Scale (for example, TXSCL for tax scale).
SPE
Service period end.
SPS
Service period start.
SPT
State payroll tax.
TKE
(Absence) take.
TMBR
Take accumulator member.
WKF
Weeks federal.
WKO
Weeks other (non-federal).
Component Names (Suffixes)
In Global Payroll for Australia, suffixes are used to name the components of earnings and deductions elements. For example, when you create an earning or deduction element in Global Payroll, you define the components that make up the element, such as base, rate, unit, and percentage. The system automatically generates the components and accumulators for the element based on the calculation rule or accumulator periods. The system also names the components and accumulators by appending a suffix to the element's name.
For example, suppose that you define the earning element named EARN1 with the following calculation rule:
EARN1 = Rate × Unit
The system automatically creates two additional elements for the components in the calculation rule: a rate element called EARN1_RATE and a unit element called EARN1_UNIT. In Global Payroll for Australia, all suffixes fall into one of the following types:
Note. To view the suffixes used for Australia, select Set Up HRMS, Product Related, Global Payroll & Absence Mgmt, System Settings, Element Suffixes.
Click to jump to top of pageClick to jump to parent topicFunctional Area Codes
The following table contains the functional area codes used in the names of Australian elements.
Description
ABS
Australian Bureau of Statistics.
ANN
Annual leave.
AUS
Australia (used for elements common to multiple features).
DED
Deduction.
EOY
End of year.
ERN
Earnings.
GLI
General Ledger Interface.
GRN
Garnishment.
LIM
Limit.
LSL
Long service leave.
LVE
Leave.
PSH
Prior service history.
RTO
Retro.
SCK
Sick leave.
SP
Salary packaging.
TAX
Tax.
TER
Termination.
Click to jump to parent topicElement Type Codes (PIN_TYPE)
Many element types, particularly supporting elements, are identified by the type code in their names. For example, the FM in AUS FM LSTSEG identifies the element as a formula.
You can view all the element types in the search page by selecting Set Up HRMS, Product Related, Global Payroll & Absence Mgmt, System Settings, Element Types. Because not all element types are delivered for Australia, some these codes do not appear in the names of Australian elements.
Click to jump to parent topicArchiving Data for Global Payroll for Australia
PeopleSoft Enterprise Global Payroll for Australia delivers an archiving tool called the Data Archive Manager with a predefined archive object (GPAU_RSLT_ARCHIVE) and an archive template (GPAURSLT) that you can use to archive your payroll results data. The delivered archive template uses queries to select and store data by calendar group ID (CAL_RUN_ID field).
Note. Please use extreme caution when making changes to delivered archive objects, queries, or templates. Any modifications can result in the loss of important data.
See Archiving Data.
Click to jump to top of pageClick to jump to parent topicAdditional Archiving Considerations
The following PeopleSoft Enterprise Global Payroll for Australia result data is not included in the GPAU_RSLT_ARCHIVE archive object because it is not associated with a calendar group ID:
Result Data Type
Data Location
Pay Leave in Advance
GPAU_ABSADV_CAL
GPAU_ABSRET_CAL
GPAU_ABSADV_SEG
GP_ABSEVT_SGPAU
CEMTEX Electronic Funds Transfer Results
GPAU_EFT_CMX_HD
GPAU_EFT_CMX_TL
GPAU_EFT_CMX_DT
Recipient Report Results
GPAU_RCPPAY_DTL
GPAU_RCPPAY_HDR
GPAU_RCPPAY_FTR
End of Year Payment Summary Results
GPAU_EE_PSM
GPAU_EE_ETP
Payment Summary Exception Results
GPAU_PSM_EXCEPT
State Payroll Tax Results
GPAU_SPT_SUMM
FBT Results
GPAU_EE_FBT
If you want to archive this data, you can set up new archive objects, queries, and templates using the Data Archive Manager, or you can use your own archiving solution.
See Also
Enterprise PeopleTools PeopleBook: Data Management, Using PeopleSoft Data Archive Manager
Click to jump to parent topicViewing Delivered Elements
The PeopleSoft system delivers a query that you can run to view the names of all delivered elements designed for Australia. Instructions for running the query are provided in the PeopleSoft Enterprise Global Payroll 9.1 PeopleBook.
See Also
Understanding How to View Delivered Elements
