This chapter contains the following topics:
Section 2.1, "How to Validate Tax IDs in Latin American Countries"
Section 2.2, "(COL and ECU) Tax Explanation Codes for Columbia and Ecuador"
The logic for validating tax IDs for customers and suppliers for Latin American users in countries for which localized solutions are available is different from the logic for users in other countries. JD Edwards EnterpriseOne software supports localized software for these Latin American countries:
Argentina
Brazil
Chile
Colombia
Ecuador
Mexico
Peru
Venezuela
The standard logic for validating tax IDs uses the country code of the customer or supplier, along with values in the Tax Id Validation (70/TI) user-defined code (UDC) table. For the Latin American countries, the logic uses the user's country code as set up in the User Profile Revisions program (P0092) when:
The user's country code is different from the supplier or customer country code, and
The user's country code is for a supported Latin American country.
For example, if the user's country code is AR (Argentina) and the supplier's country code is IT (Italy), the system:
Verifies that the IT value exists in the 70/TI UDC table.
Uses the validation routine for Argentina instead of the validation routine for Italy.
Colombian and Ecuadorian localizations use four tax explanation codes from the Tax Explanation Codes (00/EX) UDC table:
C: VAT + Sales tax
V: VAT
CT: VAT + Sales tax, tax only
VT: VAT, tax only
These tax explanation codes are hard-coded for the JD Edwards EnterpriseOne Accounts Payable and JD Edwards EnterpriseOne Accounts Receivable systems.
This table lists the country-specific setup and functionality for Colombia:
| Setup or Process | Description |
| UDCs (user-defined codes) | Set up base-software UDCs with Colombia-specific values, and set up Colombia-specific UDCs for:
| AAIs (automatic accounting instructions) | No Columbia-specific AAI setup exists. |
| Next numbers | The electronic tax reporting process requires that you set up next numbers for the header of the XML files and for each format. Set up the next number for the header in system 76C in the Next Numbers program (P0002). Set up the next number for the individual formats in the Sending Number field on the Format Setup Revision form in the DIAN General Setup program (P76C0F00). |
| Voucher and invoice processing | Before you work with voucher and invoice processing for Colombia set up UDCs 76C/RC and 76C/TC.
For vouchers that are saved in a foreign currency, the recycling process uses the exchange rate that corresponds to the invoice or the accounting date as defined in the master business functions (MBFs) for the voucher. The system reads the values in the Recycle Voucher UDC (76C/RC) to determine the version to use. See Setting Up UDCs for Accounts Payable Transactions for Colombia. |
| Address book records | The logic for validating tax IDs for customers and suppliers is different in the Address Book Revisions program (P01012) for users in the Latin American countries supported by JD Edwards EnterpriseOne software.
See How to Validate Tax IDs in Latin American Countries. In addition to the base software setup and processes for address book records, for Colombia:
| Fixed assets | In addition to the base software setup and processes for fixed assets, for Colombia you must set up:
See Setting Up Cost Accounts for Depreciation and Inflation Adjustments for Colombia. Country-specific functionality includes:
| Payment processing | In addition to the base software setup and processes for payment processing, for Colombia set up payment formats. |
| Fiscal book reports | You can generate reports for Colombia to report fiscal information.
See Reports for Colombia. |
| Reporting taxes using magnetic media | To use the JD Edwards EnterpriseOne system to report taxes:
See Understanding Tax Reporting Using Magnetic Media in Colombia. |
