This chapter contains the following topics:
Section 2.1, "The JD Edwards EnterpriseOne In-Memory Sales Advisor Solution Overview"
Section 2.2, "Limitations of JD Edwards EnterpriseOne In-Memory Sales Advisor"
The JD Edwards EnterpriseOne In-Memory Sales Advisor solution supports items in any industry that needs visibility to sales opportunities. The JD Edwards EnterpriseOne In-Memory Sales Advisor solution integrates with other JD Edwards EnterpriseOne systems from Oracle to create a complete supply chain solution.
The JD Edwards EnterpriseOne In-Memory Sales Advisor solution for Oracle Engineered Systems combines the hardware of Oracle with the application layers of JD Edwards EnterpriseOne providing unprecedented speed to gather, aggregate, and summarize real-time customer, product, and sales information.
Oracle Engineered Systems are the building blocks of integrated compute, storage, and network components designed to provide an out-of-the-box platform for a broad range of enterprise application workloads such as JD Edwards EnterpriseOne. When you run the JD Edwards EnterpriseOne In-Memory Sales Advisor solution on Oracle's Engineered Systems, you acquire quick access to information when entering sales orders. Running the JD Edwards EnterpriseOne In-Memory Sales Advisor solution on Oracle Engineered Systems enables extremely fast in-memory processing of your data.
In-memory processing means that your system can store huge amounts of data in the random access memory (RAM) of the Oracle Engineered Systems instead of in a standard database. The in-memory storage of data as you run your processes enables fast processing and fast return of process results so that you can immediately view the impact to sales orders. Because you store data in-memory, access to the data is much faster than table fetches to a standard table each time that you work with sales orders.
The JD Edwards EnterpriseOne In-Memory Sales Advisor solution enables faster decision making based on summarized large volumes of data within JD Edwards EnterpriseOne.
The JD Edwards EnterpriseOne In-Memory Sales Advisor solution drives operational improvements that help you manage sales opportunities, improve customer service, and increase profits.
The following table categorizes the benefits of using the JD Edwards EnterpriseOne In-Memory Sales Advisor solution by feature:
| Feature | Benefit |
| Dynamic Product Suggestions |
| Order Profit Display |
| Supply Monitor |
| Profitability Simulation |
