This chapter contains the following topics:
This guide includes information about generating electronic invoices in the Core Invoice (EN16391) template. The European Union countries are allowed to define a country-specific version (CIUS). EnterpriseOne Localizations for European Union allows customers to generate the required electronic invoices in XML based on EN16391 standards using a common template. You can modify this template based on the country-specific version (CIUS) before submitting the invoice to the tax authority.
In addition to the setup described in this guide, you must set up the base software for the particular process you implement. For example, you must follow the steps to set up the base software JD Edwards EnterpriseOne Accounts Receivable system in addition to performing the setup for any country-specific functionality for the JD Edwards EnterpriseOne Accounts Receivable system.
To enable a country-specific functionality without modifying or disrupting the standard software functionality or processes, see:
Localizations: Country Server Methodology (R96450) (Doc ID 2205125.2).
In the planning phase of your implementation, take advantage of all JD Edwards EnterpriseOne sources of information, including the installation guides and troubleshooting information.
When determining which electronic software updates (ESUs) to install for JD Edwards EnterpriseOne systems, use the EnterpriseOne and World Change Assistant. EnterpriseOne and World Change Assistant, a Java-based tool, reduces the time required to search and download ESUs by 75 percent or more and enables you to install multiple ESUs at one time.
See https://updatecenter.oracle.com/res/deploy/GA/ChangeAssistant.jnlp.
