csx_AccessConfigurationRegister(9F)
csx_Parse_CISTPL_BYTEORDER(9F)
csx_Parse_CISTPL_CFTABLE_ENTRY(9F)
csx_Parse_CISTPL_DEVICEGEO(9F)
csx_Parse_CISTPL_DEVICEGEO_A(9F)
csx_Parse_CISTPL_DEVICE_OA(9F)
csx_Parse_CISTPL_DEVICE_OC(9F)
csx_Parse_CISTPL_LINKTARGET(9F)
csx_Parse_CISTPL_LONGLINK_A(9F)
csx_Parse_CISTPL_LONGLINK_C(9F)
csx_Parse_CISTPL_LONGLINK_MFC(9F)
ddi_get_soft_iblock_cookie(9F)
ddi_intr_get_supported_types(9F)
ddi_prop_lookup_byte_array(9F)
ddi_prop_lookup_int64_array(9F)
ddi_prop_lookup_string_array(9F)
ddi_prop_update_byte_array(9F)
ddi_prop_update_int64_array(9F)
ddi_prop_update_string_array(9F)
ldi_prop_lookup_byte_array(9F)
ldi_prop_lookup_int64_array(9F)
ldi_prop_lookup_string_array(9F)
mac_prop_info_set_default_link_flowctrl(9F)
mac_prop_info_set_default_str(9F)
mac_prop_info_set_default_uint8(9F)
mac_prop_info_set_range_uint32(9F)
net_event_notify_unregister(9F)
net_instance_notify_register(9F)
net_instance_notify_unregister(9F)
net_instance_protocol_unregister(9F)
net_protocol_notify_register(9F)
nvlist_lookup_boolean_array(9F)
nvlist_lookup_boolean_value(9F)
nvlist_lookup_nvlist_array(9F)
nvlist_lookup_string_array(9F)
nvlist_lookup_uint16_array(9F)
nvlist_lookup_uint32_array(9F)
nvlist_lookup_uint64_array(9F)
nvpair_value_boolean_array(9F)
scsi_get_device_type_scsi_options(9F)
usb_get_current_frame_number(9F)
usb_get_max_pkts_per_isoc_request(9F)
usb_pipe_get_max_bulk_transfer_size(9F)
usb_pipe_stop_intr_polling(9F)
usb_pipe_stop_isoc_polling(9F)
- check whether DDI_SUSPEND might result in power being removed from a device
#include <sys/ddi.h> #include <sys/sunddi.h> int ddi_removing_power(dev_info_t *dip);
Solaris DDI specific (Solaris DDI)
The ddi_removing_power() function indicates whether a currently pending call into a driver's detach(9E) entry point with a command of DDI_SUSPEND is likely to result in power being removed from the device.
ddi_removing_power() can return true and power still not be removed from the device due to a failure to suspend and power off the system.
The ddi_removing_power() function supports the following parameter:
pointer to the device's dev_info structure
The ddi_removing_power() function returns:
Power might be removed by the framework as a result of the pending DDI_SUSPEND call.
Power will not be removed by the framework as a result of the pending DDI_SUSPEND call.
Example 1 Protecting a Tape from Abrupt Power Removal
A tape driver that has hardware that would damage the tape if power is removed might include this code in its detach(9E) code:
int
xxdetach(dev_info_t *dip, ddi_detach_cmd_t cmd)
case DDI_SUSPEND:
* We do not allow DDI_SUSPEND if power will be removed and
* we have a device that damages tape when power is removed
* We do support DDI_SUSPEND for Device Reconfiguration, however.
if (ddi_removing_power(dip) && xxdamages_tape(dip))
return (DDI_FAILURE);
...See attributes(5) for descriptions of the following attributes:
attributes(5), cpr(7), attach(9E), detach(9E)
Writing Device Drivers
