Integrated Lights Out Manager (ILOM) Administration Guide for ILOM 1.1.1
Command-Line Interface Reference
A.1 CLI Command Quick Reference
This section contains the most common ILOM commands used to administer your Sun server from the command-line interface (CLI).
TABLE A-1 Command Syntax and Usage
Content
Typeface
Description
Your input
Fixed-width bold
Text that you type. Type it exactly as shown.
Onscreen output
Fixed-width regular
Text that the computer displays.
Variable
Italic
Replace these with a name or value you choose.
Square brackets [ ]
Text in square brackets is optional.
Vertical bars |
Text separated by a vertical bar represents the only available values. Select one.
TABLE A-2 General Commands
Description
Command
Show all valid targets.
help targets
Log out of the CLI.
exit
Display the version of the ILOM firmware running on the ILOM.
version
Display clock information.
show /SP/clock
Display all of the CLI commands.
show /SP/cli/commands
Display the active ILOM sessions.
show /SP/sessions
Display information about commands and targets.
help
Display information about a specific command.
help create
Update the ILOM and BIOS firmware.
load -source tftp://newSPimage
Display a list of the ILOM event logs.
show /SP/logs/event/list
TABLE A-3 User Commands
Description
Command
Add a local user.
create /SP/users/user1 password=password
role=administrator|operator
Delete a local user.
delete /SP/users/user1
Change a local user's properties.
set /SP/users/user1 role=operator
Display information about all local users.
show -display [targets|properties|all]
-level [value|all] /SP/users
Display information about LDAP settings.
show /SP/clients/ldap
Change LDAP settings.
set /SP/clients/ldap binddn=proxyuser
bindpw=proxyuserpassword
defaultrole=administrator|operator
ipaddress=ipaddress
TABLE A-4 Network and Serial Port Setting Commands
Description
Command
Display network configuration information.
show /SP/network
Change network properties for the ILOM. Changing certain network properties, like the IP address, will disconnect your active session.
set /SP/network pendingipaddress=ipaddress pendingipdiscovery=dchp|static
pendingipgateway=ipgateway
pendingipnetmask=ipnetmask commitpending=true
Display information about the external serial port.
show /SP/serial/external
Change the external serial port configuration.
set /SP/serial/external pendingspeed=integer commitpending=true
Display information about the serial connection to the host.
show /SP/serial/host
Change the host serial port configuration.
Note: This speed setting must match the speed setting for serial port 0, COM1 or /dev/ttyS0 on the host operating system.
set /SP/serial/host pendingspeed=integer commitpending=true
TABLE A-5 Alert Commands
Description
Command
Display information about PET alerts. You can configure up to 15 alerts.
show /SP/alert/rules/1...15
Change alert configuration.
set /SP/alert/rules/1...15 destination=ipaddress level=down|critical|major|minor
TABLE A-6 System Management Access Commands
Description
Command
Display information about HTTP settings.
show /SP/services/http
Change HTTP settings, such as enabling automatic redirection to HTTPS.
set /SP/services/http port=portnumber secureredirect enabled|disabled
servicestate=enabled|disabled
Display information about HTTPS access.
show /SP/services/https
Change HTTPS settings.
set /SP/services/https port=portnumber servicestate=enabled|disabled
Display ssh DSA
key settings.
show /SP/services/ssh/keys/dsa
Display ssh RSA
key settings.
show /SP/services/ssh/keys/rsa
TABLE A-7 SNMP Commands
Description
Command
Display information about SNMP settings. By default, the SNMP port is 161 and v3 is enabled.
show /SP/services/snmp engineid=snmpengineid
port=snmpportnumber sets=enabled|disabled
v1=enabled|disabled v2c=enabled|disabled
v3=enabled|disabled
Display SNMP users.
show /SP/services/snmp/users
Add an SNMP user.
create /SP/services/snmp/users/snmpusername authenticationpassword=password
authenticationprotocol=MD5|SHA
permissions=rw|ro privacypassword=password privacyprotocol=none|DES
Delete an SNMP user.
delete /SP/services/snmp/users/snmpusername
Display information about SNMP public (read-only) communities.
show /SP/services/snmp/communities/public
Add this device to an SNMP public community.
create /SP/services/snmp/communities/
public/comm1
Delete this device from an SNMP public community.
delete /SP/services/snmp/communities/
public/comm1
Display information about SNMP private (read-write) communities.
show /SP/services/snmp/communities/private
Add this device to an SNMP private community.
private/comm2
Delete this device from an SNMP private community.
private/comm2
TABLE A-8 Host System Commands
Description
Command
Start the host system.
start /SYS
Stop the host system.
stop /SYS
Reset the host system.
reset /SYS
Start a session to connect to the host console.
start /SP/console
Stop the session connected to the host console.
stop /SP/console
TABLE A-9 Clock Settings
Description
Command
Set the ILOM clock to synchronize with a primary NTP server.
set /SP/clients/ntp/server/1 address=ntpIPaddress
Set the ILOM clock to synchronize with a secondary NTP server.
set /SP/clients/ntp/server/2 addressntpIPaddress2
A.2 CLI Command Reference
This section provides reference information about the CLI commands.
A.2.1 Using the cd Command
Use the cd command to navigate the namespace. When you cd to a target location, that location then becomes the default target for all other commands. Using the -default option with no target returns you to the top of the namespace. Typing just cd displays your current location in the namespace. Typing help targets displays a list of all targets in the entire namespace.
Syntax
cd target
Options
[-d|default] [-h|help]
Targets and Properties
Any location in the namespace.
Examples
To create a user named sally, cd to /SP/users, then execute the create command with /SP/users as the default target.
-> cd /SP/users
-> create sally
To find your location, type cd.
-> cd /SP/users
A.2.2 Using the create Command
Use the create command to set up an object in the namespace. Unless you specify properties with the create command, they are empty.
Syntax
create [options] target [propertyname=value]
Options
Targets, Properties, and Values
TABLE A-10 Targets, Properties, and Values for the create Command
Valid Targets
Properties
Values
Default
/SP/users/username
password
role
<string>
administrator/operator
(none)
operator
/SP/services/snmp/community/
communityname
permissions
ro|rw
ro
/SP/services/snmp/user/
username
permissions
privacyprotocol
privacypassword
MD5
<string>
ro|rw
none|DES
<string>
MD5
(null string)
ro
DES
(null string)
Example
-> create /SP/users/susan role=administrator
A.2.3 Using the delete Command
Use the delete command to remove an object from the namespace. You will be prompted to confirm a delete command. Eliminate this prompt by using the
-script option.
Syntax
delete [options] [-script] target
Options
[-f|force] [-h|help] [-script]
Targets
TABLE A-11 Targets for the delete Command
Valid Targets
/SP/users/username
/SP/services/snmp/community/communityname
/SP/services/snmp/user/username
Examples
-> delete /SP/users/susan
-> delete -script /SP/alert/rules/tojohn
A.2.4 Using the exit Command
Use the exit command to terminate a session to the CLI.
Syntax
exit [options]
Options
[-h|help]
A.2.5 Using the help Command
Use the help command to display Help information about commands and targets. Using the -output terse option displays usage information only. The -output verbose option displays usage, description, and additional information including examples of command usage. If you do not use the -output option, usage information and a brief description of the command are displayed.
Specifying command targets displays a complete list of valid targets for that command from the fixed targets in /SP and /SYS. Fixed targets are targets that cannot be created by a user.
Specifying command targets legal displays copyright information and product use rights.
Syntax
help [options] command [targets]
Options
[-h|help] [-output terse|verbose]
Commands
cd, create, delete, exit, help, load, reset, set, show, start, stop, version
Examples
-> help load
The load command is used to transfer a file from a server to a target.
Usage: load -source URL [target]
-source : specify the location to get a file
-> help -output verbose reset
The reset command is used to reset a target.
Usage: reset [-script] [target]
Available options for this command:
-script : do not prompt for yes/no confirmation and act as if yes was specified.
Examples:
-> reset /SYS
Are you sure you want to reset /SYS (y/n)? y
Performing hard reset on /SYS
-> reset
/SP Are you sure you want to reset /SP (y/n)? n
Command aborted. ->
A.2.6 Using the load Command
Use the load command to transfer an image file from a source, indicated by a Uniform Resource Indicator (URI), to update the ILOM firmware. The URI can specify a protocol and credentials used for the transfer. Only the TFTP protocol is supported, so the URL must begin with tftp://. If credentials are required and not specified, the command prompts you for a password.
Note - Use this command to update your ILOM firmware and BIOS.
Syntax
load -source URL
Options
[-h|help] [-source]
Examples
-> load -source tftp://archive/newmainimage
-> load -source tftp://10.6.22.32/tftp_files/file.ima
-> load -source tftp://tftpserver.sun.com/file.ima
Note - A firmware upgrade will cause the server and ILOM to be reset. It is recommended that a clean shutdown of the server be done prior to the upgrade procedure. An upgrade takes about five minutes to complete. ILOM enters a special mode to load new firmware. No other tasks can be performed in ILOM until the firmware upgrade is complete and ILOM is reset.
Are you sure you want to load the specified file (y/n)? y
File upload is complete.
Firmware image verification is complete.
Do you want to preserve the configuration (y/n)? n
Updating firmware in flash RAM:
Firmware update is complete.
ILOM will not be restarted with the new firmware.
A.2.7 Using the reset Command
Use the reset command to reset the state of the target. You will be prompted to confirm a reset operation. Eliminate this prompt by using the -script option.
Note - The reset command does not affect the power state of hardware devices.
Syntax
reset [options] target
Options
[-h|help] [-script]
Targets
TABLE A-12 Targets for the reset Command
Valid Targets
/SP
/SYS
Examples
-> reset /SP
-> reset /SYS
A.2.8 Using the set Command
Use the set command to specify the properties of the target.
Syntax
set [options] [-default] target [propertyname=value]
Options
[-x examine] [-h help]
TABLE A-13 Targets, Properties, and Values for the set Command
Valid Targets
Properties
Values
Default
/SP/users/username
password
role
<string>
(none)
operator
/SP/alert/rules/rulename
(rulename = 1 through 15)
level
destination
disable|information|warning|critical|non-recoverable
<ipaddress>
critical
(none)
/SP/clock
usentpserver
enabled|disabled
/SP/clock
/SP/services/http
servicestate
enabled|disabled
/SP/services/http
/SP/services/https
servicestate
enabled|disabled
/SP/services/https
/SP/services/snmp
engineid
port
sets
traps
v1
v2c
v3
<hexadecimal>
<decimal>
enabled|disabled
enabled|disabled
enabled|disabled
enabled|disabled
enabled|disabled
IP address
161
disabled
disabled
disabled
disabled
enabled
/SP/services/snmp/
permissions
ro|rw
ro
/username
permissions
privacyprotocol
privacypassword
MD5
<string>
ro|rw
none|DES
<string>
MD5
(null string)
ro
DES
(null string)
/SP/clients/ldap
binddn
bindpw
defaultrole
ipaddress
port
searchbase
state
<username>
<string>
<ipaddress>|none
<decimal>
<string>
enable|disabled
(none)
(none)
operator
none
389
(none)
disabled
/SP/clients/radius
defaultrole
ipaddress
port
secret
state
administrator|operator<ipaddress>|none
<decimal>
<string>|none
enable|disabled
operator
none
1812
none
disabled
/SP/clients/servers/[1|2]
address
<IP address>|<hostname>|
none
(none)
/SP/network
commitpending
pendingipaddress
pendingdiscovery
pendingipgateway
pendingipnetmask
true
<IP address>|none
dhcp|static
<IP address>|none
<IP dotted decimal>
(none)
(none)
dhcp
(none)
255.255.255.255
/SP/serial/external
commitpending
flowcontrol
pendingspeed
true
none
<decimal from list>
(none)
none
9600
/SP/serial/host
commitpending
pendingspeed
true
<decimal from list>
(none)
9600
Examples
-> set /SP/users/susan role=administrator
-> set /SP/clients/ldap state=enabled binddn=proxyuser bindpw=ez24get
A.2.9 Using the show Command
Use the show command to display information about targets and properties.
Using the -display option determines the type of information shown. If you specify -display targets, then all targets in the namespace below the current target are shown. If you specify -display properties, all property names and values for the target are shown. With this option you can specify certain property names, and only those values are shown. If you specify -display all, all targets in the namespace below the current target are shown, and the properties of the specified target are shown. If you do not specify a -display option, the show command acts as if -display all was specified.
The -level option controls the depth of the show command and it applies to all modes of the -display option. Specifying -level 1 displays the level of the namespace where the object exists. Values greater than 1 return information for the target's current level in the namespace and the <specified value> levels below. If the argument is -level all, it applies to the current level in the namespace and everything below.
Syntax
show [options] [-display targets|properties|all] [-level value|all] target [propertyname]
Options
[-d|-display] [-e|examine] [-l|level]
TABLE A-14 Targets for the show Command
Valid Targets
Properties
/SYS
/SP
/SP/alert
/SP/alert/rules/alertrulename
type
level
destination
/SP/clients/ldap
binddn
bindpw
defaultrole
ipaddress
port
searchbase
state
/SP/clients/radius
defaultrole
ipaddress
port
secret
state
/SP/clients/ntp
/SP/clients/ntp/server/[1|2]
/SP/clock
datetime
usentpserver
/SP/logs
/SP/logs/event
clear
/SP/logs/event/list
/SP/network
commitpending
ipaddress
ipdiscovery
ipgateway
ipnetmask
linkstatus
macaddress
pendingipaddress
pendingdiscovery
pendingipgateway
pendingipnetmask
/SP/serial
/SP/serial/external
commitpending
flowcontrol
pendingspeed
speed
/SP/serial/host
commitpending
pendingspeed
speed
/SP/services
/SP/services/http
port
secureredirect
servicestate
/SP/services/https
port
servicestate
/SP/services/snmp
ngineid
port
sets
traps
v1
v2c
v3
permissions
permissions
/SP/services/ssh
fingerprint
length
publickey
fingerprint
length
publickey
/SP/sessions
/SP/sessions/sessionid
starttime
source
type
user
/SP/users
/SP/users/username
role
Examples
-> show -display properties /SP/users/susan
/SP/users/susan
Properties:
role = Administrator
TABLE A-15
-> show /SP/clients -level 2
/SP/clients
Targets:
ldap
ntp
Properties:
Commands:
cd
show
/SP/clients/ldap
Targets:
Properties:
binddn = cn=Manager,dc=sun,dc=com
bindpw = secret
defaultrole = Operator
ipaddress = 129.144.97.180
port = 389
searchbase = ou=people,dc=sun,dc=com
state = disabled
Commands:
cd
show
/SP/clients/ntp
Targets:
server
Properties:
Commands:
cd
show
A.2.10 Using the start Command
Use the start command to turn on the target or to initiate a connection to the host console.
Syntax
start [options] target
Options
[-h|help] [-state]
Targets
TABLE A-16 Targets for the start Command
Valid Targets
Description
/SYS
Starts (powers on) the system.
/SP/console
Starts an interactive session to the console stream.
Examples
-> start /SP/console
-> start /SYS
A.2.11 Using the stop Command
Use the stop command to shut down the target or to terminate another user's connection to the host console. You will be prompted to confirm a stop command. Eliminate this prompt by using the -script option.
Syntax
stop [options] [-script] target
Options
Targets
TABLE A-17 Targets for the stop Command
Valid Targets
Description
/SYS
Perform an orderly shutdown, followed by a power off of the specified hardware. Use the -force option to skip the orderly shutdown and force an immediate power off.
/SP/console
Terminate another user's connection to the host console.
Examples
-> stop /SP/console
-> stop -force /SYS
A.2.12 Using the version Command
Use the version command to display ILOM version information.
Syntax
version
Options
[-h|help]
Example
-> version
version SP firmware version: 1.0.0
SP firmware build number: 4415
SP firmware date: Mon Mar 28 10:39:46 EST 2005
SP filesystem version: 0.1.9
820-0280-12
Copyright © 2007, Sun Microsystems, Inc. All Rights Reserved.
