 To Deactivate an Active Project
To Deactivate an Active ProjectIf the Container Manager GUI is not already open, access it as described in To Start the Container Manager GUI.
In the Hosts view, select the host with which the project is associated.
Select the Projects tab in the right panel.
A table appears that lists all projects that are associated with that host.
To enable the Deactivate button, select the check box of the project to be activated.
(Optional) View and modify the properties of the project.
Click the name of the project in the Project Name column of the table.
The Properties tab appears.
(Optional) Modify the resource reservations for the project and click Save.
For more information, see Modifying Containers and Projects.
Click the Deactivate button.
The project is deactivated and the resource boundaries are not enforced by the kernel.
