Installing and Administering Solaris Container Manager 1.1
ProcedureTo View a Resource Change Job Log
Use this procedure to view the log for a change job that has been completed. If the job included changes to multiple hosts, the status for the jobs per host is located in the log.
Steps
  1. If the Container Manager GUI is not already open, access it as described in To Start the Container Manager GUI.
  2. Select the Containers view in the navigation window.
  3. Select the Jobs tab from the right pane.
  4. From the Resource Change Jobs table, select the completed job whose log you want to view by selecting the check box next to the name.
    A check mark appears in the box.
  5. Click the View Log button.
    The log file for the resource change job appears.
