Installing and Administering Solaris Container Manager 1.1
ProcedureTo View the Processes Running in a Project From the Hosts View
Use this procedure if you know the name of the host with which the project is associated.
Steps
  1. If the Container Manager GUI is not already open, access it as described in To Start the Container Manager GUI.
  2. Select the Hosts view by clicking the left tab in the navigation window.
  3. In the navigation window, select the host with which the project is associated.
  4. In the right pane, select the Projects tab.
    The Projects table is displayed and lists all the projects that are associated with the host. The list includes active and inactive projects. You must select an active project to see information about its processes.
  5. Select the project by clicking the project name.
    The properties page for the project instance on the selected host is displayed.
  6. Select the Processes tab.
    The processes running inside the project are displayed in the Processes table. The name of the project and the host it is associated with are displayed above the table.
    If no processes are listed, you might have selected an inactive container.
