Installing and Administering Solaris Container Manager 1.1
ProcedureTo View the Processes Running in a Project From the Containers View
Use this procedure when you know the name of the project and want to select from the list of hosts with which the project is associated.
Steps
  1. If the Container Manager GUI is not already open, access it as described in To Start the Container Manager GUI.
  2. Select the Containers view by clicking the right tab in the navigation window.
  3. In the navigation window, select the desired container.
    If needed, expand the container by clicking the expansion triangle. After the project names appear, click the name of the desired project.
    A table that lists all the hosts that the container is associated with is displayed in the right pane.
  4. In the table, click the project name.
    The properties page for the container instance on the selected host appears.
  5. Select the Processes tab.
    The name of the project and the host it is associated with are displayed in the table title. The processes that are running inside the project are displayed in the Processes table.
    If no processes are listed in the table, you might have selected an inactive project.
