The Master Index Data Manager provides the following functions so you can maintain the patient records in the master index database:
View patient records
Compare patient records
Merge and unmerge patient records
Compare records that are flagged as possible duplicates
Resolve or merge potential duplicate records
Review and reverse automatic record matches made by the master index
Create reports on master index data and statistics, including records added or updated, potential duplicates, merged and unmerged records, and so on
The MIDM is accessed through a web browser, and requires you to log in before you can access any patient information. The URL for the MIDM is:
http://host:http_port/app_nameMIDM |
where
host is the name of the server machine.
http_port is the HTTP port number of the application server.
app_name is the name of the master index application.
The default URL for the PIX/PDQ Manager MIDM is:
http://localhost:8080/PatientMIDM |
Make sure you have a login ID and password.
Make sure the GlassFish server is running.
Launch a web browser.
In the Address field, enter the appropriate URL.
The login page appears.
In the upper right portion of the page, select the language for the MIDM display.
Enter your user ID and password in the appropriate fields.
Click Login.
The initial page appears. (By default, the initial page is the Record Details page, but this is configurable.)
