Getting Started with the Java Dynamic Management Kit 5.0
SNMPv3 Security Configuration
The configuration for SNMPv3 user-based security is located in a text file, called the security file. Each SNMP engine has its own security file. See the Java Dynamic Management Kit 5.0 Tutorial for information about the user security file and how to configure it.
You can view examples of security files at:
installDir/SUNWjdmk/jdmk5.0/examples/Snmp
