The standard login starts the desktop on a single screen. You can edit the Xconfig file to have the desktop start on multiple screens. You must be logged in as the root user to change this file.
For faster editing of login configuration information, use the Failsafe Session option to run a single xterm window rather than the whole desktop.
Create a copy of the Xserver file by typing the following command and pressing Return:
# cp /usr/dt/config/Xservers /etc/dt/config/Xservers
/etc/dt/config/Xservers overrides /usr/dt/config/Xservers.
Edit the /etc/dt/config/Xservers file to set up two frame buffers (screens):
Choose Reset Login Screen from the Options menu.
When running Solaris CDE on multiple screens, a Front Panel is displayed on each screen. These Front Panels are independent of each other and have separate configuration files.
