Solaris Advanced User's Guide
Changing the Default Authorization Protocol
You can change the default authorization protocol, MIT-MAGIC-COOKIE-1, to SUN_DES-1, the other supported authorization protocol, or to no user-based access mechanism at all. You can change the default authorization protocol by editing the Xsun line in the /usr/dt/config/Xservers file. For example, to change the default from MIT-MAGIC-COOKIE-1 to SUN-DES-1, add the -auth sun-des option to the Xsun command by editing the following line in the /usr/dt/config/Xservers file.
:0  Local local_uid@console root /usr/openwin/bin/Xsun :0 -nobanner -auth sun-des
If you must run the Solaris operating environment without the user-based access mechanism, add the -noauth option to the Xsun command by editing the following line in the /usr/dt/config/Xservers file.
:0  Local local_uid@console root /usr/openwin/bin/Xsun :0 -nobanner -noauth
Caution – Caution –
By using the -noauth option, you weaken security. It is equivalent to running Solaris software with the host-based access control mechanism only. The server inactivates the user-based access control mechanism. Anyone who can run applications on your local machine is allowed access to your server.
