Dynamic routing is the easiest way to manage routing on a host. Hosts that use dynamic routing run the routing protocols provided by the in.routed daemon for IPv4 or in.ripngd daemon for IPv6. Use the next procedure to enable IPv4 dynamic routing on a single interface host. For more information about dynamic routing, refer to Packet Forwarding and Routing on IPv4 Networks.
On the host, assume the Primary Administrator role or become superuser.
The Primary Administrator role includes the Primary Administrator profile. To create the role and assign the role to a user, see Chapter 2, Working With the Solaris Management Console (Tasks), in System Administration Guide: Basic Administration.
Verify whether the /etc/defaultrouter file exists.
# cd /etc # ls | grep defaultrouter |
If /etc/defaultrouter exists, delete any entry that you find there.
An empty /etc/defaultrouter file forces the host to use dynamic routing.
Verify whether packet forwarding and routing are enabled on the host.
# routeadm
Configuration Current Current
Option Configuration System State
IPv4 routing disabled disabled
IPv6 routing disabled disabled
IPv4 forwarding enabled enabled
IPv6 forwarding disabled disabled
Routing services "route:default ripng:default"
If packet forwarding is enabled, turn it off
Use either of the following commands:
For the routeadm command, type the following:
# routeadm -d ipv4-forwarding -u |
To use SMF, type the following:
# svcadm disable ipv4-forwarding |
Enable routing protocols on the host.
# routeadm -e ipv4-routing -u |
# svcadm enable route:default |
Now IPv4 dynamic routing is enabled. The host's routing table is dynamically maintained by the in.routed daemon.
The following example shows how to configure dynamic routing for hosta, a single-interface host on the network 192.168.5.0 that is shown in Figure 5–3. hosta currently uses Router 1 as its default router. However, hosta now needs to run dynamic routing.
First, you would log in to hosta as superuser or assume an equivalent role. Then, you would determine whether the /etc/defaultrouter file is present on the host:
# cd /etc # ls | grep defaultrouter defaultrouter |
The response from grep indicates that a /etc/defaultrouter file exists for hosta.
# vi /etc/defaultrouter 192.168.5.10 |
The file has the entry 192.168.5.10, which is the IP address for Router 1. You would delete this entry to enable static routing. Next, you would need to verify whether packet forwarding and routing are already enabled for the host.
# routeadm Configuration Current Current
IPv4 forwarding disabled disabled
Both routing and packet forwarding are turned off for hosta. Turn on routing to complete the configuration of dynamic routing for hosta, as follows:
