You can use the mipagentstat command to display a foreign agent's visitors list and a home agent's binding table. Mobile IP Mobility Agent Status provides a conceptual description of the mipagentstat command. You can also review the mipagentstat(1M) man page.
Become superuser or assume an equivalent role on the system where you are enabling Mobile IP.
Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
Display the mobility agent status.
# mipagentstat options |
Shows the list of active mobile nodes in the foreign agent's visitor list.
Shows the list of active mobile nodes in the home agent's binding table.
Shows the list of security associations with an agent's mobility agent peers.
This example shows how to display the visitor list for all mobile nodes that are registered with a foreign agent.
# mipagentstat -f |
As a result, output similar to the following is displayed:
Mobile Node Home Agent Time (s) Time (s) Flags
Granted Remaining
foobar.xyz.com ha1.xyz.com 600 125 .....T.
10.1.5.23 10.1.5.1 1000 10 .....T.
Foreign ..... Security Association(s)..... Agent Requests Replies FTunnel RTunnel ---------------------- -------- -------- -------- -------- forn-agent.eng.sun.com AH AH ESP ESP |
This example shows how to display home agent security associations.
# mipagentstat -fp |
Home ..... Security Association(s) ..... Agent Requests Replies FTunnel RTunnel ---------------------- -------- -------- -------- -------- home-agent.eng.sun.com AH AH ESP ESP ha1.xyz.com AH,ESP AH AH,ESP AH,ESP |
