You can use the mipagentstat command to display a foreign agent's visitor list and a home agent's binding table. You can also display the security associations with an agent's mobility agent peers. To display the foreign agent visitor list, you use the mipagentstat command's -f option. To display the home agent binding table, you use the mipagentstat command's -h option. The following examples show typical output when the mipagentstat command is used with these options.
Mobile Node Home Agent Time (s) Time (s) Flags
Granted Remaining
foobar.xyz.com ha1.xyz.com 600 125 .....T.
10.1.5.23 10.1.5.1 1000 10 .....T.
Granted Remaining
foobar.xyz.com fa1.tuv.com 600 125 .....T.
10.1.5.23 123.2.5.12 1000 10 .....T.
See the mipagentstat(1M) man page for more information about the command's options. Displaying Mobility Agent Status provides procedures that use the mipagentstat command.
