System Administration Guide: Security Services
Chapter 14 Solaris Cryptographic Framework (Tasks)
This chapter describes how to use the Solaris Cryptographic Framework. The following is a list of information in this chapter.
Using the Cryptographic Framework (Task Map)
The following task map points to tasks for using the cryptographic framework.
Task
Description
For Instructions
Protect individual files or sets of files
Ensures that file content has not been tampered with. Prevents files from being read by intruders. These procedures can be done by ordinary users.
Protecting Files With the Solaris Cryptographic Framework (Task Map)
Administer the framework
Adds, configures, and removes software providers. Disables and enables hardware provider mechanisms. These procedures are administrative procedures.
Administering the Cryptographic Framework (Task Map)
Sign a provider
Enables a provider to be added to the Solaris Cryptographic Framework. These procedures are developer procedures.
Appendix F, Packaging and Signing Cryptographic Providers, in Oracle Solaris Security for Developers Guide.
The Solaris Cryptographic Framework can help you protect your files. The following task map points to procedures for listing the available algorithms, and for protecting your files cryptographically.
Task
Description
For Instructions
Generate a symmetric key
Generates a random key for use with algorithms that the user specifies.
How to Generate a Symmetric Key by Using the dd Command
Generates a key of user-specified length. Optionally, stores the key in a file, a PKCS #11 keystore, or an NSS keystore.
How to Generate a Symmetric Key by Using the pktool Command
Provide a checksum that ensures the integrity of a file
Verifies that the receiver's copy of a file is identical to the file that was sent.
How to Compute a Digest of a File
Protect a file with a message authentication code (MAC)
Verifies to the receiver of your message that you were the sender.
How to Compute a MAC of a File
Encrypt a file, and then decrypt the encrypted file
Protects the content of files by encrypting the file. Provides the encryption parameters to decrypt the file.
How to Encrypt and Decrypt a File
This section describes how to generate symmetric keys, how to create checksums for file integrity, and how to protect files from eavesdropping. The commands in this section can be run by regular users. Developers can write scripts that use these commands.
ProcedureHow to Generate a Symmetric Key by Using the dd Command
A key is needed to encrypt files and to generate the MAC of a file. The key should be derived from a random pool of numbers.
If your site has a random number generator, use the generator. Otherwise, you can use the dd command with the Solaris /dev/urandom device as input. For more information, see the dd(1M) man page.
  1. Determine the key length that your algorithm requires.
    1. List the available algorithms.
      % encrypt -l
      Algorithm       Keysize:  Min   Max (bits)
      aes                       128   128
      arcfour                     8   128
      des                        64    64
      3des                      192   192
      % mac -l
      des_mac                    64    64
      sha1_hmac                   8   512
      md5_hmac                    8   512
      sha256_hmac                 8   512
      sha384_hmac                 8  1024
      sha512_hmac                 8  1024
    2. Determine the key length in bytes to pass to the dd command.
      Divide the minimum and maximum key sizes by 8. When the minimum and maximum key sizes are different, intermediate key sizes are possible. For example, the value 8, 16, or 64 can be passed to the dd command for the sha1_hmac and md5_hmac functions.
  2. Generate the symmetric key.
    % dd if=/dev/urandom of=keyfile bs=n count=n
    if=file
    Is the input file. For a random key, use the /dev/urandom file.
    of=keyfile
    Is the output file that holds the generated key.
    bs=n
    Is the key size in bytes. For the length in bytes, divide the key length in bits by 8.
    count=n
    Is the count of the input blocks. The number for n should be 1.
  3. Store your key in a protected directory.
    The key file should not be readable by anyone but the user.
    % chmod 400 keyfile
Example 14–1 Creating a Key for the AES Algorithm
In the following example, a secret key for the AES algorithm is created. The key is also stored for later decryption. AES mechanisms use a 128-bit key. The key is expressed as 16 bytes in the dd command.
% ls -al ~/keyf
drwx------   2 jdoe  staff        512 May 3 11:32 ./
% dd if=/dev/urandom of=$HOME/keyf/05.07.aes16 bs=16  count=1
% chmod 400 ~/keyf/05.07.aes16
Example 14–2 Creating a Key for the DES Algorithm
In the following example, a secret key for the DES algorithm is created. The key is also stored for later decryption. DES mechanisms use a 64-bit key. The key is expressed as 8 bytes in the dd command.
% dd if=/dev/urandom of=$HOME/keyf/05.07.des8 bs=8  count=1
% chmod 400 ~/keyf/05.07.des8
Example 14–3 Creating a Key for the 3DES Algorithm
In the following example, a secret key for the 3DES algorithm is created. The key is also stored for later decryption. 3DES mechanisms use a 192-bit key. The key is expressed as 24 bytes in the dd command.
% dd if=/dev/urandom of=$HOME/keyf/05.07.3des.24 bs=24 count=1
% chmod 400 ~/keyf/05.07.3des.24
Example 14–4 Creating a Key for the MD5 Algorithm
In the following example, a secret key for the MD5 algorithm is created. The key is also stored for later decryption. The key is expressed as 64 bytes in the dd command.
% dd if=/dev/urandom of=$HOME/keyf/05.07.mack64 bs=64 count=1
% chmod 400 ~/keyf/05.07.mack64
ProcedureHow to Generate a Symmetric Key by Using the pktool Command
Some applications require a symmetric key for encryption and decryption of communications. In this procedure, you create a symmetric key and store it.
  1. (Optional) If you plan to use a keystore, create it.
  2. Generate a random number for use as a symmetric key.
    Use one of the following methods.
    • Generate a key and store it in a file.
      The advantage of a file-stored key is that you can extract the key from this file for use in an application's key file, such as the /etc/inet/secret/ipseckeys file or IPsec.
      % pktool genkey keystore=file outkey=key-fn \
      [keytype=specific-symmetric-algorithm] [keylen=size-in-bits] \
      [dir=directory] [print=n]
      keystore
      The value file specifies the file type of storage location for the key.
      outkey=key-fn
      Is the filename when keystore=file.
      For a particular algorithm, specify aes, arcfour, des, or 3des.
      keylen=size-in-bits
      Is the length of the key in bits. The number must be divisible by 8. Do not specify for des or 3des.
      dir=directory
      Is the directory path to key-fn. By default, directory is the current directory.
      print=n
      Prints the key to the terminal window. By default, the value of print is n.
    • Generate a key and store it in a PKCS #11 keystore.
      The advantage of the PKCS #11 keystore is that you can retrieve the key by its label. This method is useful for keys that encrypt and decrypt files. You must complete Step 1 before using this method.
      % pktool genkey label=key-label \
      [token=token] [sensitive=n] [extractable=y] [print=n]
      label=key-label
      Is a user-specified label for the key. The key can be retrieved from the keystore by its label.
      keylen=size-in-bits
      token=token
      Is the token name. By default, the token is Sun Software PKCS#11 softtoken.
      sensitive=n
      Specifies the sensitivity of the key. When the value is y, the key cannot be printed by using the print=y argument. By default, the value of sensitive is n.
      extractable=y
      Specifies that the key can be extracted from the keystore. Specify n to prevent the key from being extracted.
      print=n
    • Generate a key and store it in an NSS keystore.
      % pktool keystore=nss genkey label=key-label \
      [keytype=[keytype=specific-symmetric-algorithm] [keylen=size-in-bits] [token=token] \
      [dir=directory-path] [prefix=database-prefix]
      keystore
      The value nss specifies the NSS type of storage location for the key.
      label=key-label
      keylen=size-in-bits
      token=token
      Is the token name. By default, the token is the NSS internal token.
      dir=directory
      Is the directory path to the NSS database. By default, directory is the current directory.
      prefix=directory
      Is the prefix to the NSS database. The default is no prefix.
      print=n
  3. (Optional) Verify that the key exists.
    Use one of the following commands, depending on where you stored the key.
    • Verify the key in the key-fn file.
      % pktool list keystore=file objtype=key infile=key-fn
      Found n keys.
      Key #1 - keytype:location (keylen)
    • Verify the key in the PKCS #11 or the NSS keystore.
      $ pktool list objtype=key
      Enter PIN for keystore:
      Found n keys.
Example 14–5 Creating a DES Key by Using the pktool Command
In the following example, a secret key for the DES algorithm is created. The key is stored in a local file for later decryption. The command protects the file with 400 permissions. When the key is created, the print=y option displays the generated key in the terminal window.
DES mechanisms use a 64-bit key. The user who owns the keyfile retrieves the key by using the od command.
% pktool genkey keystore=file outkey=64bit.file1 keytype=des print=y
        Key Value ="a3237b2c0a8ff9b3"
% od -x 64bit.file1
0000000 a323 7b2c 0a8f f9b3
ProcedureHow to Compute a Digest of a File
When you compute a digest of a file, you can check to see that the file has not been tampered with by comparing digest outputs. A digest does not alter the original file.
  1. List the available digest algorithms.
    % digest -l
    md5
    sha1
    sha256
    sha384
    sha512
  2. Compute the digest of the file and save the digest listing.
    Provide an algorithm with the digest command.
    % digest -v -a algorithm input-file > digest-listing
    -v
    Displays the output in the following format:
    algorithm (input-file) = digest
    -a algorithm
    Is the algorithm to use to compute a digest of the file. Type the algorithm as the algorithm appears in the output of Step 1.
    input-file
    Is the input file for the digest command.
    digest-listing
    Is the output file for the digest command.
Example 14–6 Computing a Digest With the MD5 Mechanism
In the following example, the digest command uses the MD5 mechanism to compute a digest for an email attachment.
% digest -v -a md5 email.attach >>  $HOME/digest.emails.05.07
% cat  ~/digest.emails.05.07
md5 (email.attach) = 85c0a53d1a5cc71ea34d9ee7b1b28b01
When the -v option is not used, the digest is saved with no accompanying information:
% digest -a md5 email.attach >>  $HOME/digest.emails.05.07
Example 14–7 Computing a Digest With the SHA1 Mechanism
In the following example, the digest command uses the SHA1 mechanism to provide a directory listing. The results are placed in a file.
% digest -v -a sha1 docs/* > $HOME/digest.docs.legal.05.07
% more ~/digest.docs.legal.05.07
sha1 (docs/legal1) = 1df50e8ad219e34f0b911e097b7b588e31f9b435
sha1 (docs/legal2) = 68efa5a636291bde8f33e046eb33508c94842c38
sha1 (docs/legal3) = 085d991238d61bd0cfa2946c183be8e32cccf6c9
sha1 (docs/legal4) = f3085eae7e2c8d008816564fdf28027d10e1d983
ProcedureHow to Compute a MAC of a File
A message authentication code, or MAC, computes a digest for the file and uses a secret key to further protect the digest. A MAC does not alter the original file.
  1. List the available mechanisms.
    % mac -l
    des_mac                    64    64
    sha1_hmac                   8   512
    md5_hmac                    8   512
    sha256_hmac                 8   512
    sha384_hmac                 8  1024
    sha512_hmac                 8  1024
  2. Generate a symmetric key of the appropriate length.
    You have two options. You can provide a passphrase from which a key will be generated. Or you can provide a key.
    • If you provide a passphrase, you must store or remember the passphrase. If you store the passphrase online, the passphrase file should be readable only by you.
    • If you provide a key, it must be the correct size for the mechanism. For the procedure, see How to Generate a Symmetric Key by Using the dd Command.
  3. Create a MAC for a file.
    Provide a key and use a symmetric key algorithm with the mac command.
    % mac -v -a algorithm [ -k keyfile ] input-file
    -v
    algorithm (input-file) = mac
    -a algorithm
    Is the algorithm to use to compute the MAC. Type the algorithm as the algorithm appears in the output of the mac -l command.
    -k keyfile
    Is the file that contains a key of algorithm-specified length.
    input-file
    Is the input file for the MAC.
Example 14–8 Computing a MAC With DES_MAC and a Passphrase
In the following example, the email attachment is authenticated with the DES_MAC mechanism and a key that is derived from a passphrase. The MAC listing is saved to a file. If the passphrase is stored in a file, the file should not be readable by anyone but the user.
% mac -v -a des_mac email.attach
Enter passphrase: <Type passphrase>
des_mac (email.attach) = dd27870a
% echo "des_mac (email.attach) = dd27870a" >> ~/desmac.daily.05.07
Example 14–9 Computing a MAC With MD5_HMAC and a Key File
In the following example, the email attachment is authenticated with the MD5_HMAC mechanism and a secret key. The MAC listing is saved to a file.
% mac -v -a md5_hmac -k $HOME/keyf/05.07.mack64 email.attach
md5_hmac (email.attach) = 02df6eb6c123ff25d78877eb1d55710c
% echo "md5_hmac (email.attach) = 02df6eb6c123ff25d78877eb1d55710c" \
>> ~/mac.daily.05.07
Example 14–10 Computing a MAC With SHA1_HMAC and a Key File
In the following example, the directory manifest is authenticated with the SHA1_HMAC mechanism and a secret key. The results are placed in a file.
% mac -v -a sha1_hmac \
-k $HOME/keyf/05.07.mack64 docs/* > $HOME/mac.docs.legal.05.07
% more ~/mac.docs.legal.05.07
sha1_hmac (docs/legal1) = 9b31536d3b3c0c6b25d653418db8e765e17fe07a
sha1_hmac (docs/legal2) = 865af61a3002f8a457462a428cdb1a88c1b51ff5
sha1_hmac (docs/legal3) = 076c944cb2528536c9aebd3b9fbe367e07b61dc7
sha1_hmac (docs/legal4) = 7aede27602ef6e4454748cbd3821e0152e45beb4
ProcedureHow to Encrypt and Decrypt a File
When you encrypt a file, the original file is not removed or changed. The output file is encrypted.
For solutions to common errors from the encrypt command, see the section that follows the examples.
  1. Create a symmetric key of the appropriate length.
  2. Encrypt a file.
    Provide a key and use a symmetric key algorithm with the encrypt command.
    % encrypt -a algorithm  [ -k keyfile ] -i input-file -o output-file
    -a algorithm
    Is the algorithm to use to encrypt the file. Type the algorithm as the algorithm appears in the output of the encrypt -l command.
    -k keyfile
    Is the file that contains a key of algorithm-specified length. The key length for each algorithm is listed, in bits, in the output of the encrypt -l command.
    -i input-file
    Is the input file that you want to encrypt. This file is left unchanged by the command.
    -o output-file
    Is the output file that is the encrypted form of the input file.
Example 14–11 Encrypting and Decrypting With AES and a Passphrase
In the following example, a file is encrypted with the AES algorithm. The key is generated from the passphrase. If the passphrase is stored in a file, the file should not be readable by anyone but the user.
% encrypt -a aes -i ticket.to.ride -o ~/enc/e.ticket.to.ride
Re-enter passphrase: Type passphrase again
The input file, ticket.to.ride, still exists in its original form.
To decrypt the output file, the user uses the same passphrase and encryption mechanism that encrypted the file.
% decrypt -a aes -i ~/enc/e.ticket.to.ride -o ~/d.ticket.to.ride
Example 14–12 Encrypting and Decrypting With AES and a Key File
In the following example, a file is encrypted with the AES algorithm. AES mechanisms use a key of 128 bits, or 16 bytes.
% encrypt -a aes -k ~/keyf/05.07.aes16 \
To decrypt the output file, the user uses the same key and encryption mechanism that encrypted the file.
% decrypt -a aes -k ~/keyf/05.07.aes16  \
Example 14–13 Encrypting and Decrypting With ARCFOUR and a Key File
In the following example, a file is encrypted with the ARCFOUR algorithm. The ARCFOUR algorithm accepts a key of 8 bits (1 byte), 64 bits (8 bytes), or 128 bits (16 bytes).
% encrypt -a arcfour -i personal.txt \
-k ~/keyf/05.07.rc4.8 -o ~/enc/e.personal.txt
% decrypt -a arcfour -i ~/enc/e.personal.txt \
-k ~/keyf/05.07.rc4.8 -o ~/personal.txt
Example 14–14 Encrypting and Decrypting With 3DES and a Key File
In the following example, a file is encrypted with the 3DES algorithm. The 3DES algorithm requires a key of 192 bits, or 24 bytes.
% encrypt -a 3des -k ~/keyf/05.07.des24 \
-i ~/personal2.txt -o ~/enc/e.personal2.txt
% decrypt -a 3des -k ~/keyf/05.07.des24 \
-i ~/enc/e.personal2.txt -o ~/personal2.txt
Troubleshooting
The following messages indicate that the key that you provided to the encrypt command is not permitted by the algorithm that you are using.
If you pass a key that does not meet the requirements of the algorithm, you must supply a better key.
The following task map points to procedures for administering software and hardware providers in the Solaris Cryptographic Framework.
Task
Description
For Instructions
List the providers in the Solaris Cryptographic Framework
Lists the algorithms, libraries, and hardware devices that are available for use in the Solaris Cryptographic Framework.
How to List Available Providers
Add a software provider
Adds a PKCS #11 library or a kernel module to the Solaris Cryptographic Framework. The provider must be signed.
How to Add a Software Provider
Prevent the use of a user-level mechanism
Removes a software mechanism from use. The mechanism can be enabled again.
How to Prevent the Use of a User-Level Mechanism
Temporarily disable mechanisms from a kernel module
Temporarily removes a mechanism from use. Usually used for testing.
How to Prevent the Use of a Kernel Software Provider
Uninstall a provider
Removes a kernel software provider from use.
Example 14–22
List available hardware providers
Shows the attached hardware, shows the mechanisms that the hardware provides, and shows which mechanisms are enabled for use.
How to List Hardware Providers
Disable mechanisms from a hardware provider
Ensures that selected mechanisms on a hardware accelerator are not used.
How to Disable Hardware Provider Mechanisms and Features
Restart or refresh cryptographic services
Ensures that cryptographic services are available.
How to Refresh or Restart All Cryptographic Services
This section describes how to administer the software providers and the hardware providers in the Solaris Cryptographic Framework. Software providers and hardware providers can be removed from use when desirable. For example, you can disable the implementation of an algorithm from one software provider. You can then force the system to use the algorithm from a different software provider.
ProcedureHow to List Available Providers
The Solaris Cryptographic Framework provides algorithms for several types of consumers:
  1. List the providers in a brief format.
    Note –
    The contents and format of the providers list varies for different Solaris releases. Run the cryptoadm list command on your system to see the providers that your system supports.
    Only those mechanisms at the user level are available for use by regular users.
    % cryptoadm list
    user-level providers:
        /usr/lib/security/$ISA/pkcs11_kernel.so
        /usr/lib/security/$ISA/pkcs11_softtoken.so
    kernel software providers:
        des
        aes
        blowfish
        arcfour
        sha1
        md5
        rsa
    kernel hardware providers:
        ncp/0
  2. List the providers and their mechanisms in the Solaris Cryptographic Framework.
    All mechanisms are listed in the following output. However, some of the listed mechanisms might be unavailable for use. To list only the mechanisms that the administrator has approved for use, see Example 14–16.
    The output is reformatted for display purposes.
    % cryptoadm list -m
    /usr/lib/security/$ISA/pkcs11_kernel.so: CKM_MD5,CKM_MD5_HMAC,
    CKM_MD5_HMAC_GENERAL,CKM_SHA_1,CKM_SHA_1_HMAC,CKM_SHA_1_HMAC_GENERAL,
    /usr/lib/security/$ISA/pkcs11_softtoken.so:
    CKM_DES_CBC,CKM_DES_CBC_PAD,CKM_DES_ECB,CKM_DES_KEY_GEN,
    CKM_DES3_CBC,CKM_DES3_CBC_PAD,CKM_DES3_ECB,CKM_DES3_KEY_GEN,
    CKM_AES_CBC,CKM_AES_CBC_PAD,CKM_AES_ECB,CKM_AES_KEY_GEN,
    des: CKM_DES_ECB,CKM_DES_CBC,CKM_DES3_ECB,CKM_DES3_CBC
    aes: CKM_AES_ECB,CKM_AES_CBC
    blowfish: CKM_BF_ECB,CKM_BF_CBC
    arcfour: CKM_RC4
    sha1: CKM_SHA_1,CKM_SHA_1_HMAC,CKM_SHA_1_HMAC_GENERAL
    md5: CKM_MD5,CKM_MD5_HMAC,CKM_MD5_HMAC_GENERAL
    rsa: CKM_RSA_PKCS,CKM_RSA_X_509,CKM_MD5_RSA_PKCS,CKM_SHA1_RSA_PKCS
    swrand: No mechanisms presented.
    ncp/0: CKM_DSA,CKM_RSA_X_509,CKM_RSA_PKCS,CKM_RSA_PKCS_KEY_PAIR_GEN,
    CKM_DH_PKCS_KEY_PAIR_GEN,CKM_DH_PKCS_DERIVE,CKM_EC_KEY_PAIR_GEN,
    CKM_ECDH1_DERIVE,CKM_ECDSA
Example 14–15 Finding the Existing Cryptographic Mechanisms
In the following example, all mechanisms that the user-level library, pkcs11_softtoken, offers are listed.
% cryptoadm list -m provider=/usr/lib/security/\$ISA/pkcs11_softtoken.so
Mechanisms:
CKM_SSL3_KEY_AND_MAC_DERIVE,CKM_TLS_KEY_AND_MAC_DERIVE
Example 14–16 Finding the Available Cryptographic Mechanisms
Policy determines which mechanisms are available for use. The administrator sets the policy. An administrator can choose to disable mechanisms from a particular provider. The -p option displays the list of mechanisms that are permitted by the policy that the administrator has set.
% cryptoadm list -p
/usr/lib/security/$ISA/pkcs11_kernel.so: all mechanisms are enabled.
random is enabled.
/usr/lib/security/$ISA/pkcs11_softtoken.so: all mechanisms are enabled.
random is enabled.
des: all mechanisms are enabled.
aes: all mechanisms are enabled.
blowfish: all mechanisms are enabled.
arcfour: all mechanisms are enabled.
sha1: all mechanisms are enabled.
md5: all mechanisms are enabled.
rsa: all mechanisms are enabled.
swrand: random is enabled.
ncp/0: all mechanisms are enabled.
ProcedureHow to Add a Software Provider
  1. Assume the Primary Administrator role, or become superuser.
    The Primary Administrator role includes the Primary Administrator profile. To create the role and assign the role to a user, see Chapter 2, Working With the Solaris Management Console (Tasks), in System Administration Guide: Basic Administration.
  2. List the software providers that are available to the system.
    % cryptoadm list
        des
        aes
        blowfish
        arcfour
        sha1
        md5
        rsa
        ncp/0
  3. Add the provider's package by using the pkgadd command.
    # pkgadd -d /path/to/package pkginst
    The package must include software that has been signed by a certificate from Sun. To request a certificate from Sun and to sign a provider, see Appendix F, Packaging and Signing Cryptographic Providers, in Oracle Solaris Security for Developers Guide.
    The package should have scripts that notify the cryptographic framework that another provider with a set of mechanisms is available. For information about the packaging requirements, see Appendix F, Packaging and Signing Cryptographic Providers, in Oracle Solaris Security for Developers Guide.
  4. Refresh the providers.
    You need to refresh providers if you added a software provider, or if you added hardware and specified policy for the hardware.
    # svcadm refresh svc:/system/cryptosvc
  5. Locate the new provider on the list.
    In this case, a new kernel software provider was installed.
    # cryptoadm list
        des
        aes
        blowfish
        arcfour
        sha1
        md5
        rsa
        swrand
        ecc <-- added provider
Example 14–17 Adding a User-Level Software Provider
In the following example, a signed PKCS #11 library is installed.
# pkgadd -d /cdrom/cdrom0/SolarisNew
Answer the prompts
# svcadm refresh system/cryptosvc
# cryptoadm list
    /opt/SUNWconn/lib/$ISA/libpkcs11.so.1 <-- added provider
Developers who are testing a library with the cryptographic framework can install the library manually.
# cryptoadm install provider=/opt/SUNWconn/lib/\$ISA/libpkcs11.so.1
For information on getting your provider signed, see Binary Signatures for Third-Party Software.
ProcedureHow to Prevent the Use of a User-Level Mechanism
If some of the cryptographic mechanisms from a library provider should not be used, you can remove selected mechanisms. This procedure uses the DES mechanisms in the pkcs11_softtoken library as an example.
  1. Become superuser or assume a role that includes the Crypto Management rights profile.
    To create a role that includes the Crypto Management rights profile and assign the role to a user, see Example 9–7.
  2. List the mechanisms that are offered by a particular user-level software provider.
  3. List the mechanisms that are available for use.
    $ cryptoadm list -p
    random is enabled.
  4. Disable the mechanisms that should not be used.
    $ cryptoadm disable provider=/usr/lib/security/\$ISA/pkcs11_softtoken.so \
    > mechanism=CKM_DES_CBC,CKM_DES_CBC_PAD,CKM_DES_ECB
  5. List the mechanisms that are available for use.
    $ cryptoadm list -p provider=/usr/lib/security/\$ISA/pkcs11_softtoken.so
    /usr/lib/security/$ISA/pkcs11_softtoken.so: all mechanisms are enabled,
    except CKM_DES_ECB,CKM_DES_CBC_PAD,CKM_DES_CBC. random is enabled.
Example 14–18 Enabling a User-Level Software Provider Mechanism
In the following example, a disabled DES mechanism is again made available for use.
$ cryptoadm list -m provider=/usr/lib/security/\$ISA/pkcs11_softtoken.so
$ cryptoadm enable provider=/usr/lib/security/\$ISA/pkcs11_softtoken.so \
> mechanism=CKM_DES_ECB
except CKM_DES_CBC_PAD,CKM_DES_CBC. random is enabled.
Example 14–19 Enabling All User-Level Software Provider Mechanisms
In the following example, all mechanisms from the user-level library are enabled.
$ cryptoadm enable provider=/usr/lib/security/\$ISA/pkcs11_softtoken.so all
random is enabled.
Example 14–20 Permanently Removing User-Level Software Provider Availability
In the following example, the libpkcs11.so.1 library is removed.
$ cryptoadm uninstall provider=/opt/SUNWconn/lib/\$ISA/libpkcs11.so.1
$ cryptoadm list
ProcedureHow to Prevent the Use of a Kernel Software Provider
If the cryptographic framework provides multiple modes of a provider such as AES, you might remove a slow mechanism from use, or a corrupted mechanism. This procedure uses the AES algorithm as an example.
  2. List the mechanisms that are offered by a particular kernel software provider.
    $ cryptoadm list -m provider=aes
    $ cryptoadm list -p provider=aes
  4. Disable the mechanism that should not be used.
    $ cryptoadm disable provider=aes mechanism=CKM_AES_ECB
    aes: all mechanisms are enabled, except CKM_AES_ECB.
Example 14–21 Enabling a Kernel Software Provider Mechanism
In the following example, a disabled AES mechanism is again made available for use.
$ cryptoadm enable provider=aes mechanism=CKM_AES_ECB
Example 14–22 Temporarily Removing Kernel Software Provider Availability
In the following example, the AES provider is temporarily removed from use. The unload subcommand is useful to prevent a provider from being loaded automatically while the provider is being uninstalled. For example, the unload subcommand would be used when installing a patch that affects the provider.
$ cryptoadm unload provider=aes
$ cryptoadm list
    des
    aes (inactive)
    blowfish
    arcfour
    sha1
    md5
    rsa
    swrand
The AES provider is unavailable until the cryptographic framework is refreshed.
$ svcadm refresh system/cryptosvc
$ cryptoadm list
    des
    aes
    blowfish
    arcfour
    sha1
    md5
    rsa
    swrand
If a kernel consumer is using the kernel software provider, the software is not unloaded. An error message is displayed and the provider continues to be available for use.
Example 14–23 Permanently Removing Software Provider Availability
In the following example, the AES provider is removed from use. Once removed, the AES provider does not appear in the policy listing of kernel software providers.
$ cryptoadm uninstall provider=aes
$ cryptoadm list
    des
    blowfish
    arcfour
    sha1
    md5
    rsa
    swrand
If a kernel consumer is using the kernel software provider, an error message is displayed and the provider continues to be available for use.
Example 14–24 Reinstalling a Removed Kernel Software Provider
In the following example, the AES kernel software provider is reinstalled.
$ cryptoadm install provider=aes mechanism=CKM_AES_ECB,CKM_AES_CBC
$ cryptoadm list
    des
    aes
    blowfish
    arcfour
    sha1
    md5
    rsa
    swrand
ProcedureHow to List Hardware Providers
Hardware providers are automatically located and loaded. For more information, see driver.conf(4) man page.
Before You Begin
When you have hardware that expects to be used within the Solaris Cryptographic Framework, the hardware registers with the SPI in the kernel. The framework checks that the hardware driver is signed. Specifically, the framework checks that the object file of the driver is signed with a certificate that Sun issues.
For example, the Sun Crypto Accelerator 6000 board (mca), the ncp driver for the cryptographic accelerator on the UltraSPARC T1 and T2 processors (ncp), and the n2cp driver for the UltraSPARC T2 processors (n2cp) plug hardware mechanisms into the framework.
  1. List the hardware providers that are available on the system.
    % cryptoadm list
       ncp/0
  2. List the mechanisms that the chip or the board provides.
    % cryptoadm list -m provider=ncp/0
  3. List the mechanisms that are available for use on the chip or the board.
    % cryptoadm list -p provider=ncp/0
ProcedureHow to Disable Hardware Provider Mechanisms and Features
You can selectively disable mechanisms and the random number feature from a hardware provider. To enable them again, see Example 14–25. The hardware in this example, the Sun Crypto Accelerator 1000 board, provides a random number generator.
  2. Choose the mechanisms or feature to disable.
    List the hardware provider.
    # cryptoadm list
    Kernel hardware providers:
        dca/0
    • Disable selected mechanisms.
      # cryptoadm list -m provider=dca/0
      dca/0: CKM_RSA_PKCS, CKM_RSA_X_509, CKM_DSA, CKM_DES_CBC, CKM_DES3_CBC
      random is enabled.
      # cryptoadm disable provider=dca/0 mechanism=CKM_DES_CBC,CKM_DES3_CBC
      # cryptoadm list -p provider=dca/0
      dca/0: all mechanisms are enabled except CKM_DES_CBC,CKM_DES3_CBC.
      random is enabled.
    • Disable the random number generator.
      dca/0: all mechanisms are enabled. random is enabled.
      # cryptoadm disable provider=dca/0 random
      dca/0: all mechanisms are enabled. random is disabled.
    • Disable all mechanisms. Do not disable the random number generator.
      # cryptoadm disable provider=dca/0 mechanism=all
      dca/0: all mechanisms are disabled. random is enabled.
    • Disable every feature and mechanism on the hardware.
      # cryptoadm disable provider=dca/0 all
      dca/0: all mechanisms are disabled. random is disabled.
Example 14–25 Enabling Mechanisms and Features on a Hardware Provider
In the following examples, disabled mechanisms on a piece of hardware are selectively enabled.
dca/0: all mechanisms are enabled except CKM_DES_ECB,CKM_DES3_ECB
random is enabled.
# cryptoadm enable provider=dca/0 mechanism=CKM_DES3_ECB
dca/0: all mechanisms are enabled except CKM_DES_ECB.
random is enabled.
In the following example, only the random generator is enabled.
dca/0: all mechanisms are enabled, except CKM_MD5,CKM_MD5_HMAC,….
random is disabled.
# cryptoadm enable provider=dca/0 random
random is enabled.
In the following example, only the mechanisms are enabled. The random generator continues to be disabled.
random is disabled.
# cryptoadm enable provider=dca/0 mechanism=all
In the following example, every feature and mechanism on the board is enabled.
dca/0: all mechanisms are enabled, except CKM_DES_ECB,CKM_DES3_ECB.
random is disabled.
# cryptoadm enable provider=dca/0 all
ProcedureHow to Refresh or Restart All Cryptographic Services
By default, the Solaris Cryptographic Framework is enabled. When the kcfd daemon fails for any reason, the service management facility can be used to restart cryptographic services. For more information, see the smf(5) and svcadm(1M) man pages. For the effect on zones of restarting cryptographic services, see Cryptographic Services and Zones.
  1. Check the status of cryptographic services.
    % svcs cryptosvc
     STATE          STIME    FMRI
    offline         Dec_09   svc:/system/cryptosvc:default
  2. Become superuser or assume an equivalent role to enable cryptographic services.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map).
    # svcadm enable svc:/system/cryptosvc
Example 14–26 Refreshing Cryptographic Services
In the following example, cryptographic services are refreshed in the global zone. Therefore, kernel-level cryptographic policy in every non-global zone is also refreshed.
