You can use the uninstall subcommand of the prodreg command to remove software from your system. When you uninstall software by using the prodreg uninstall command, you remove a specified software and all the child components associated with that software. Before you remove software, verify that other software does not depend on the software you want to uninstall. See How to Check for Software Dependencies ( prodreg).
After you uninstall software, you can remove that software and all the child components of that software from the Oracle Solaris Product Registry by using the prodreg unregister -r command.
Become superuser or assume an equivalent role.
Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
View the information on the software you want to uninstall.
# prodreg browse -u name-UUID |
Uninstall the software.
# prodreg uninstall -u name-UUID |
Check the dependencies for the software that you want to uninstall.
# prodreg info -u name-UUID |
Check the following information in the output of the prodreg info command.
Child Components – Lists the software components that are associated with the name software component. When you unregister the name software, you also unregister the child components of name software. If the output of the previous prodreg info command lists any child components, verify that you want to unregister these child components.
Required Components – Lists the software components that are required by the name software component. Software components might require other components that are not child components. When you uninstall and unregister a component, only child components are unregistered and uninstalled.
Dependent Components – Lists the components that require name software to run. When you unregister the name software, you also unregister the dependent components of name software. If the output of the prodreg info command lists any dependent components, verify that you want to unregister these dependent components.
In the previous sample output, name software does not have any dependent components.
Check the dependencies of name software's child components.
# prodreg info -u component-a-UUID -i l -a "Dependent Components" |
The sample output shows that no other software depends on the child components of name software.
Unregister the software and its child components.
# prodreg unregister -r -u name-UUID -i 1 |
Recursively unregisters software with the unique identifier name-UUID and all the child components of this software.
Specifies the unique identifier of the software you want to unregister.
Specifies the instance of the software you want to unregister.
The following example shows how to uninstall ExampleSoft software and all the child components of ExampleSoft software.
# prodreg browse -m "ExampleSoft"
BROWSE # +/-/. UUID # NAME
1 - root 1 System
Registry
2 + a01ee8dd-1dd1-11b2-a3f2-0800209a5b6b 1 Solaris 10
System
Software
3 + 8f64eabf-1dd2-11b2-a3f1-0800209a5b6b 1 Unclassified
Software
1423 - 95842091-725a-8501-ef29-0472985982be 1 ExampleSoft
1436 . 90209809-9785-b89e-c821-0472985982be 1 Example Doc
1437 - EXSOzzt 1 Example Data
1462 . EXSOblob 1 Example Data
# prodreg uninstall -u 95842091-725a-8501-ef29-0472985982be -i 1
# prodreg info -u 95842091-725a-8501-ef29-0472985982be
Title: ExampleSoft Software
Child Components:
Name UUID #
Example Doc 90209809-9785-b89e-c821-0472985982be 1
Example Data EXSOzzt 1
Required Components:
Name UUID #
# prodreg info -u 90209809-9785-b89e-c821-0472985982be -i 1
Dependent Components:
Name UUID #
ExampleSoft 95842091-725a-8501-ef29-0472985982be 1
# prodreg info -u EXSOzzt -i 1 -a "Dependent Components"
Name UUID #
# prodreg info -u EXSOblob -i 1 -a "Dependent Components"
Name UUID #
# prodreg unregister -r -u 95842091-725a-8501-ef29-0472985982be -i 1
