Solaris のシステム管理 (デバイスとファイルシステム)
例 — テープバックアップ用の RCM スクリプト
#! /usr/bin/perl -w
   # A sample site customization RCM script.
   # When RCM_ENV_FORCE is FALSE this script indicates to RCM that it cannot
   # release the tape drive when the tape drive is being used for backup.
   # When RCM_ENV_FORCE is TRUE this script allows DR removing a tape drive
   # when the tape drive is being used for backup by killing the tape
   # backup application.
    use strict;
    my ($cmd, %dispatch);
    $cmd = shift(@ARGV);
# dispatch table for RCM commands
    %dispatch = (
            "scriptinfo"    =>      \&do_scriptinfo,
            "register"      =>      \&do_register,
            "resourceinfo"  =>      \&do_resourceinfo,
            "queryremove"   =>      \&do_preremove,
            "preremove"     =>      \&do_preremove
    if (defined($dispatch{$cmd})) {
            &{$dispatch{$cmd}};
    } else {
            exit (2);
    sub do_scriptinfo
            print "rcm_script_version=1\n";
            print "rcm_script_func_info=Tape backup appl script for DR\n";
            exit (0);
    sub do_register
            my ($dir, $f, $errmsg);
            $dir = opendir(RMT, "/dev/rmt");
            if (!$dir) {
                 $errmsg = "Unable to open /dev/rmt directory: $!";
                 print "rcm_failure_reason=$errmsg\n";
                 exit (1);
            while ($f = readdir(RMT)) {
                # ignore hidden files and multiple names for the same device
                if (($f !~ /^\./) && ($f =~ /^[0-9]+$/)) {
                        print "rcm_resource_name=/dev/rmt/$f\n";
            closedir(RMT);
            exit (0);
sub do_resourceinfo
      my ($rsrc, $unit);
      $rsrc = shift(@ARGV);
      if ($rsrc =~ /^\/dev\/rmt\/([0-9]+)$/) {
           $unit = $1;
           print "rcm_resource_usage_info=Backup Tape Unit Number $unit\n";
           exit (0);
       } else {
           print "rcm_failure_reason=Unknown tape device!\n";
            exit (1);
    sub do_preremove
            my ($rsrc);
            # check if backup application is using this resource
            #if (the backup application is not running on $rsrc) {
                    # allow the DR to continue
            #        exit (0);
            # If RCM_ENV_FORCE is FALSE deny the operation.
            # If RCM_ENV_FORCE is TRUE kill the backup application in order
            # to allow the DR operation to proceed
            if ($ENV{RCM_ENV_FORCE} eq 'TRUE') {
                 if ($cmd eq 'preremove') {
                         # kill the tape backup application
                 exit (0);
            } else {
               # indicate that the tape drive can not be released
               # since the device is being used for backup by the
               # tape backup application
               print "rcm_failure_reason=tape backup in progress pid=...\n"
               exit (3);
