Java Desktop System Email and Calendar User Guide
To Add a Shortcut
To add a shortcut to a shortcuts group, perform the following steps:
  1. Open the shortcuts group to which you want to add the shortcut.
  2. In the folder pane, select the folder for which you want to add a shortcut, then choose File -> Folder -> Add to Shortcut Bar. The folder is added to the shortcuts group as a shortcut.
