Java Desktop System Email and Calendar User Guide
To Add Default Shortcuts
You can add the default shortcuts to a shortcuts group. To add the default shortcuts to a shortcuts group, perform the following steps:
  1. Open the shortcuts group to which you want to add the default shortcuts.
  2. Right-click on a vacant space on the shortcuts bar, then choose Create Default Shortcuts from the popup menu. The default shortcuts are added to the shortcuts group.
