Classifying and Conditioning Ingress Traffic
Define an ACL and Access Group
Define Incoming Packet Priorities
Define the Traffic Classes With the class-map Command
Set the Rate and Burst Tolerance of a Traffic Stream
Classifying and Scheduling Egress Class Traffic
Define the Egress Scheduler Behavior
You can define a class of VLAN tagged packets and apply them to an interface.
SEFOS# configure terminal SEFOS(config)# mac access-list extended 50 SEFOS(config-ext-macl)# permit any any Vlan 1000 SEFOS(config-ext-macl)# exit SEFOS(config)# mac access-list extended 55 SEFOS(config-ext-macl)# permit any any SEFOS(config-ext-macl)# exit
SEFOS(config)# interface extreme-ethernet 0/3 SEFOS(config-if)# mac access-group 50 in SEFOS(config-if)# mac access-group 55 in SEFOS(config-if)# end
SEFOS# show access-lists mac 50 Extended MAC Access List 50 ----------------------------- Filter Priority : 1 Ether Type : 0 Protocol Type : 0 Vlan Id : 1000 User-Priority : 0 Destination MAC Address : 00:00:00:00:00:00 Source MAC Address : 00:00:00:00:00:00 In Port List : Ex0/3 Filter Action : Permit Status : Active
SEFOS# show access-lists mac 55 Extended MAC Access List 55 ----------------------------- Filter Priority : 1 Ether Type : 0 Protocol Type : 0 Vlan Id : 0 User-Priority : 0 Destination MAC Address : 00:00:00:00:00:00 Source MAC Address : 00:00:00:00:00:00 In Port List : Ex0/3 Filter Action : Permit Status : Active
