Configuring the RIP Topology Example
Configuring the RIP Packet Retransmission Interval and Retry Count
Reset the Retransmission Interval and Retry Count
Configuring the RIP Passive Interface
Enable the RIP Passive Interface
Disable the RIP Passive Interface
Configuring the Default Metric
Managing the auto-summary Option
Disable the auto-summary Option
Enable the auto-summary Option
Configuring Interface-Specific RIP Parameters
Configuring Interface-Specific Authentication
Configuring the RIP Default Route Propagation
Configuring the Version for Receiving RIP Advertisement
Configuring the Summary Address
Configuring the split-horizon Option
SEFOS# configure terminal SEFOS(config)# router rip SEFOS(config-router)# network 10.0.0.1
SEFOS(config-router)# ip rip retransmission interval 10
SEFOS(config-router)# ip rip retransmission retries 20
SEFOS# show ip protocols Routing Protocol is rip Vrf default RIP2 security level is Minimum Redistributing : rip Output Delay is disabled Retransmission timeout interval is 10 seconds Number of retransmission retries is 20 Default metric is 3 Auto-Summarisation of routes is enabled Routing for Networks : 10.0.0.0 Routing Information Sources : Interface Specific Address Summarization : Trusted Neighors : Interface vlan1 Sending updates every 30 seconds Invalid after 180 seconds Flushed after 120 seconds Send version is 1 2, receive version is 1 2 Authentication type is none Split Horizon with poissoned reverse is enabled Restrcts default route installation Restricts default route origination
