Configuring the RIP Topology Example
Configuring the RIP Packet Retransmission Interval and Retry Count
Set the RIP Packet Retransmission Interval and Retry Count
Reset the Retransmission Interval and Retry Count
Configuring the RIP Passive Interface
Enable the RIP Passive Interface
Disable the RIP Passive Interface
Configuring the Default Metric
Managing the auto-summary Option
Disable the auto-summary Option
Enable the auto-summary Option
Configuring Interface-Specific RIP Parameters
Configuring Interface-Specific Authentication
Configuring the RIP Default Route Propagation
Configuring the Version for Receiving RIP Advertisement
Configuring the Summary Address
Configuring the split-horizon Option
SEFOS# configure terminal SEFOS(config)# router rip
SEFOS(config-router)# no redistribute static SEFOS(config-router)# end
The routes were made unreachable with a metric as infinity (16). The static routes are redistributed into the RIP domain.
SEFOS# show ip rip database 10.0.0.0/8 [1] auto-summary 10.0.0.0/16 [1] directly connected, vlan1 50.0.0.0/8 [16] via 10.0.0.1, vlan1 60.0.0.0/8 [16] via 10.0.0.1, vlan1 70.0.0.0/8 [16] via 10.0.0.1, vlan1 80.0.0.0/8 [16] via 10.0.0.1, vlan1
SEFOS# show ip route C 10.0.0.0/16 is directly connected, vlan1 C 30.2.2.0/24 is directly connected, vlan3
