Enable IGS on a Specific VLAN Interface
Configure Multicast Forwarding Mode
Disable a Multicast Router Port
Configure the Multicast Router Port Time-Out Value
Configuring IGS Querier Settings
Configure the IGMP Snooping Query Interval
Configuring the Port-Purge Interval
Disable the Fast Leave Process
Configuring the Report Suppression Interval
Enable the Report Suppression Interval
Disable the Report Suppression Interval
Configuring the Group Query Interval Value
Set the Group Query Interval Value
Reset the Group Query Interval
Configuring the Group Retry Count Value
Set the Group Retry Count Value
Reset the Group Retry Count Value
Reset Report Forwarding to the Default Value
Clearing the Snooping Statistics
Clear the Statistics for a Specific VLAN
Clear the Statistics for All VLANs
Configuring the General Query Transmission Option
Enable the General Query Transmission Option
Disable the General Query Transmission Option
Flow-Based Configuration Example
Configure the MAC-Based Multicast Forwarding Mode
Configure the IP-Based Multicast Forwarding Mode
Configure a Static Router Port
You can configure multicast router ports for a VLAN statically, or the port can be learned dynamically. Whenever a port receives a query message, then that port is also added to the multicast router port list. This section contains procedures that explain how to enable or disable multicast router ports. Before you can configure IGS features, you must configure your network environment, as described in Topology Example.
