Enable IGS on a Specific VLAN Interface
Configure Multicast Forwarding Mode
Configuring a Multicast Router Port
Disable a Multicast Router Port
Configure the Multicast Router Port Time-Out Value
Configuring IGS Querier Settings
Configure the IGMP Snooping Query Interval
Configuring the Port-Purge Interval
Disable the Fast Leave Process
Configuring the Report Suppression Interval
Enable the Report Suppression Interval
Disable the Report Suppression Interval
Configuring the Group Query Interval Value
Set the Group Query Interval Value
Reset the Group Query Interval
Configuring the Group Retry Count Value
Set the Group Retry Count Value
Reset the Group Retry Count Value
Reset Report Forwarding to the Default Value
Clearing the Snooping Statistics
Clear the Statistics for a Specific VLAN
Clear the Statistics for All VLANs
Configuring the General Query Transmission Option
Enable the General Query Transmission Option
Disable the General Query Transmission Option
Flow-Based Configuration Example
Configure the MAC-Based Multicast Forwarding Mode
Configure the IP-Based Multicast Forwarding Mode
Configure a Static Router Port
Configuring the fast leave processing removes the interface from the forwarding table as soon as the switch receives a leave message from the interface (that is, the switch refrains from sending MAC-based general queries over the interface). The VLAN interface is pruned from the multicast tree for the multicast group specified in the original leave message. Configuring the immediate-leave processing ensures optimal bandwidth management for all of the hosts on a switched network, even when multiple multicast groups are simultaneously in use. You can use the same instructions to enable or disable the leave process to immediate. Before you can configure IGS features, you must configure your network environment, as described in Topology Example.
