Configuring the SLB Topology Example
SLB Configuration Guidelines and Prerequisites
Configuring the SLB-L2 Topology Example
Sample SLB-L2 Topology Example
SLB-L2 Configuration Guidelines and Prerequisites
Conditions for a Member Participating in Load Distribution
Set the Traffic Distribution Policy
Restore the Default Traffic Distribution Policy
View the Traffic Distribution Policy
Restore the Default Failover Method
Creating Example SLB Configurations
Creating a Basic SLB Configuration
Save the Current Configuration
Creating a Separate VLAN SLB Configuration
Configuration With Separate VLANs Steps
Creating a Multiple SLB Group Configuration
Multiple-SLB-Group Configuration
Configuration With Multiple SLB Groups Steps
Set Up the Servers in SLB Group 1
Set Up the Servers in SLB Group 2
Restart the Server Following Failure
Creating SLB-L2 Configuration Examples
Bump-In-The-Wire Configuration
Creating a Single-Switch Configuration
Basic Single-Switch Configuration
Create a Single-Switch Configuration
Creating a Dual-Switch Configuration
Create a Dual-Switch Configuration
When the port 16 is repaired and recovered, use the following commands to ensure that the port status has returned to active.
SEFOS# configure terminal SEFOS(config)# interface extreme-ethernet 0/16 SEFOS(config-if)# no hutdown SEFOS(config-if)# end
SEFOS# show slb l2 L2 SLB Group #1 Failover Method: Failover to All ports Members: Port State Comments ==== ===== ================= 15 ACTIVE 16 ACTIVE 17 ACTIVE 18 ACTIVE
Port 16 is now resumed to active state.
