Configuring the SLB Topology Example
SLB Configuration Guidelines and Prerequisites
Configuring the SLB-L2 Topology Example
Sample SLB-L2 Topology Example
SLB-L2 Configuration Guidelines and Prerequisites
Conditions for a Member Participating in Load Distribution
Set the Traffic Distribution Policy
Restore the Default Traffic Distribution Policy
View the Traffic Distribution Policy
Restore the Default Failover Method
Creating Example SLB Configurations
Creating a Basic SLB Configuration
Save the Current Configuration
Creating a Separate VLAN SLB Configuration
Configuration With Separate VLANs Steps
Creating a Multiple SLB Group Configuration
Multiple-SLB-Group Configuration
Configuration With Multiple SLB Groups Steps
Set Up the Servers in SLB Group 1
Set Up the Servers in SLB Group 2
Restart the Server Following Failure
Creating SLB-L2 Configuration Examples
Bump-In-The-Wire Configuration
Creating a Single-Switch Configuration
Basic Single-Switch Configuration
Create a Single-Switch Configuration
Creating a Dual-Switch Configuration
Create a Dual-Switch Configuration
SLB-L2 monitors the link interface between the server and the switch. When the link fails, a failover event takes place. SLB-L2 provides several failover options. Refer to the slb l2 failover-method command in the Sun Ethernet Fabric Operating System CLI Base Reference Manual for more information.
The following example illustrates a failover event. The LBG in this example has four active nodes.
SEFOS# show slb l2 L2 SLB Group #1 Failover Method: Failover to All ports Port Members: Port State Comments ==== ===== ================= 15 ACTIVE 16 ACTIVE 17 ACTIVE 18 ACTIVE
