| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System ONET Administration Guide |
Stopping SEFOS Before Starting ONET
show onet <onet-id> [counters] Command
show interfaces description Command
show mac-address-table Command
speed port <interface-type> <interface> { 1000 | 10000 } Command
-> start /NEM/onet Are you sure you want to start /NEM/onet (y/n)? y start: Please wait while onet comes up, this can take anywhere from 30 seconds to 2 minutes depending on the configuration ........................ start: ONET Enabled successfully.
If you reset the switch while ONET is running, ONET will be running once it is restarted.
