Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
ONET Administration Guide
PDF
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
ONET Configuration
ONET Example Configuration
Deafult Settings
ONET and Oracle ILOM
Start ONET From Oracle ILOM
Start the ONET CLI
Stopping SEFOS Before Starting ONET
Stop SEFOS
Start ONET
Stop ONET
ONET CLI Commands and Outputs
help Command
show onet <onet-id> [counters] Command
show onets Command
show interfaces description Command
show vlan Command
show lldp Command
show mac-address-table Command
speed port <interface-type> <interface> { 1000 | 10000 } Command
exit Command
Product Notes
For late-breaking information and known issues about the following products, refer to the product notes at:
Sun Blade 6000 Ethernet Switched NEM 24p 10GbE:
http://www.oracle.com/pls/topic/lookup?ctx=SB6K-24p-10GbE
