Supported Versions of Oracle Solaris OS, Firmware, and Software
Determining Oracle Solaris 11 OS Package Update Version
Determining Oracle Solaris 10 Patch Revision
Minimum Required Patchset for Oracle Solaris 10 08/11 OS
Minimum Required Patchset for Oracle Solaris 10 09/10 OS
Minimum Required Patchsets and SPARC Bundle for Oracle Solaris 10 10/09 OS
ALOM CMT Compatibility Shell Not Supported
Power Supply Inrush/Input Surge Current Information
Custom nvalias Settings Will Not Change During a System Reconfiguration
Sun Type 6 Keyboards Are Not Supported by SPARC T3 Series Servers
Hardware RAID 1E Not Supported
Enable Flow Control (With a System Reboot)
Enable Flow Control (Without a System Reboot)
Server Panics When Booting From a USB Thumbdrive Attached to the Front USB Ports (CR 6983185)
Copper QSFP Cables Not Supported (CR 6941888)
Error Messages Not Retained After UE and CE Memory Failures (CR 6990058)
Watchdog Timeouts Might Occur Under Very Heavy Load (CR 6994535)
Unrecoverable USB Hardware Errors Occur In Some Circumstances (CR 6995634)
Replace Faulty DIMMs With Uncorrectable Errors (UEs) As Soon As Possible (CR 6996144)
Intermittent Power Supply Faults Occur During Power On (CR 7066165)
Static/Dynamic Input/Output Not Currently Supported
Oracle Solaris OS Has Changed How It Specifies Logical Device Names
Oracle Solaris Jumpstart Examples
Interactive Installation Example
The cfgadm -al Command Takes a Long Time to Print Output (CR 6937169)
False nxge Warning Messages (CR 6938085)
Spurious Interrupt Message in System Console (CR 6963563)
The prtpicl Command Does Not Display Drive Information (CR 6963594)
Missing Interrupt Causes USB Hub Hotplug Thread to Hang, Resulting In Process Hangs (CR 6968801)
Long Local Console Delays During Login or Logout of Oracle Solaris (CR 6971884)
Spurious Error Message During Initial Oracle Solaris OS Installation (CR 6971896)
SDIO Policy Violations Might Cause the Primary Domain To Panic During Boot (CR 6983964)
Oracle Enterprise Manager Process Hangs and Becomes Unkillable (CR 6994300)
Intermittent WARNING: ios#, peu# Link Width x8 Link Speed GEN1 Messages (CR 6958263)
Cold Reset Adds One Day to System Time (CR 7127740)
Performing stop /SYS with HOST_COOLDOWN Policy Enabled Generates a Critical Voltage Fault
This section describes issues related to server components.
Only certain PCIe cards can be used as direct I/O endpoint devices on an I/O domain. You can still use other cards in your Oracle VM Server for SPARC environment, but these other cards cannot be used with the Direct I/O feature. Instead, these PCIe cards can be used for service domains and for I/O domains that have entire root complexes assigned to them.
For the most up-to-date list of PCIe cards that support the Sirect I/O feature, refer to https://support.oracle.com/CSP/main/article?cmd=show&type=NOT&doctype=REFERENCE&id=1325454.1
Note - Not all cards listed on the Direct I/O web page are supported in the SPARC T3-4 server. Check the server hardware compatibility list before installing any PCIe cards.
Sun Type 6 keyboards cannot be used with SPARC T3 series servers.
Although hardware RAID 0 and 1 are supported on the SPARC T3-4 server, hardware RAID 1E is not supported. Other RAID formats are available through software RAID.
Excessive packet loss has been seen when three or more ports are used across multiple Sun Dual 10GbE SFP+ PCIe cards. This loss is likely to significantly degrade trasmit and receive performance. When only two ports are used, packet loss is minimal and transmit/receive performance is as expected.
Workaround:
If you are experiencing network performance issues, use one of the following procedures to enable flow control for the interfaces. This will greatly reduce packet loss and improve performance.
fm_capable = 0; flow_control = 3; tx_queue_number = 2; rx_queue_number = 6; intr_throttling = 1000;
# update_drv ixgbe
When HOST_LAST_POWER_STATE() is set to enabled and then the system goes through an AC power cycle, the host sometimes is shown as OFF when the power up operation completes. This status information might be false.
Recovery:
Power cycle the system again to clear the false status information.
When attempting to boot a USB thumbdrive (portable USB flash drive) inserted in one of the front USB ports (USB2 or USB3), the server will panic and fail to boot.
Workaround:
Use the server's rear USB ports (USB0 or USB1) whenever booting off of an external USB thumbdrive.
The SPARC T3-4 Server 10 Gb Network Module does not support copper QSFP cables. The network module supports only optical QSFP transceiver modules and cables.
Workaround:
Use the cable specified in the list of supported system options.
If you hot-plug a Dual 10GbE SFP+ PCIe2.0 Niantic EM Network Interface Card (NIC) (part number 1110A-Z) into a PCI Express Module slot that had previously held a 4-Port (Cu) PCIe (x4) Northstar ExpressModule (part number (X)7284A-Z-N), the expected performance benefit of the Dual 10GbE SFP+ PCIe2.0 Niantic NIC might not occur.
This problem does not occur if the slot was previously unoccupied, or if it had been occupied by any other option card. This problem does this occur if the card is present when the system is powered on.
Workaround:
Hot-plug the Dual 10Gbe SFP+ PCIe2.0 Niantic EM card a second time, using one of the following methods.
Use the cfgadm (1m) command to disconnect, then reconnect, the card:
# cfgadm -c disconnect slot-name # cfgadm -c configure slot-name
Use the hotplug(1M) command to disable and poweroff the device, and then poweron and enable the device:
# hotplug disable device-path slot-name # hotplug poweroffdevice-path slot-name # hotplug poweron device-path slot-name # hotplug enable device-path slot-name
Use the Attention (ATTN) button on the card to deconfigure and then reconfigure the card.
Note - You don't need to physically remove and re-insert the card as part of the second hot plug operation.
If your server's memory experiences a uncorrectable error (UE) followed by a correctable error (CE), the correct error messages will not be generated and they will not be retained by the service processor. You will not be able to diagnose the memory problem.
Workaround:
Reboot the system. If memory problems persist, contact your service representative for assistance.
In certain unusual heavy workloads, the host may appear to suddenly reset back to OBP without any sign of a crash or a panic. The ILOM event log contains a “Host watchdog expired” entry.
Display the SP event log:
-> show /SP/logs/event/list
If this issue is affecting the server, the event log contains an entry labelled, “Host watchdog expired.”
Workaround:
Contact your authorized service provider to see if a fix is available.
You can also extend the watchdog timeout period by adding this entry to the Oracle Solaris /etc/system file:
set watchdog_timeout = 600000
This extends the watchdog timeout period to 10 minutes (600,000 milliseconds).
In extreme cases, you can also disable the watchdog timeout altogether by adding this entry to the /etc/system file:
set watchdog_enabled = 0
Note - You must reboot the server for any /etc/system modification to take effect.
In some rare instances, unrecoverable USB hardware errors occur, such as the following:
usba: WARNING: /pci@400/pci@1/pci@0/pci@8/pci@0/usb@0,2 (ehci0): Unrecoverable USB Hardware Error usba: WARNING: /pci@400/pci@1/pci@0/pci@8/pci@0/usb@0,1/hub@1/hub@3 (hubd5): Connecting device on port 2 failed
Workaround:
Reboot the system. Contact your service representative if these error messages persist.
If a DIMM has an uncorrectable error (UE), the server will generate a fault.memory.bank error that labels a DIMM as faulty. You can view this error using the Oracle ILOM show faulty command or the fmdump -v command.
If a DIMM in your system contains a persistent uncorrectable error (an error that continually occurs even after multiple reboots), replace this DIMM as soon as possible to avoid any server downtime.
Workaround:
Instead of scheduling downtime to replace the faulty DIMMs, replace the faulty DIMMs as soon as possible. Contact your service representative for assistance.
The service processor (SP) does not always initialize when AC power is removed for less than 120 seconds.
Workaround:
To initialize the SP, unplug all four server power cords. Wait at least 120 seconds before reconnecting the power cords.
In rare instances, the system FRU power-up probing routine might fail to list all installed system power supplies. The power supplies themselves are not faulted, but commands listing system FRUs do not show the presence of the non-probed power supply.
The fault sets the system fault LED, but no power supply fault LED is illuminated. To find the fault, use the fmadm utility from the ILOM fault management shell.
Start the fmadm utility from the ILOM CLI:
-> start /SP/faultmgmt/shell Are you sure you want to start /SP/faultmgmt/shell (y/n)? y faultmgmtsp>
To view the fault, type the following:
faultmgmtsp> fmadm faulty
Time UUID msgid Severity
2011-09-21/13:59:35 f13524d6-9970-4002-c2e6-de5d750f4088 ILOM-8000-2V Major
Fault class : fault.fruid.corrupt
FRU : /SYS/PS0
(Part Number: 300-2159)
(Serial Number: 476856F+1115CC0001)
Description : A Field Replaceable Unit (FRU) has a corrupt FRUID SEEPROM
Response : The service-required LED may be illuminated on the affected
FRU and chassis.
Impact : The system may not be able to use one or more components on
the affected FRU. This may prevent the system from powering
on.
Action : The administrator should review the ILOM event log for
additional information pertaining to this diagnosis. Please
refer to the Details section of the Knowledge Article for
additional information.
Workaround:
From the fault management shell prompt, clear the fault, exit the fault management shell, and reset the SP. For example:
-> start /SP/faultmgmt/shell Are you sure you want to start /SP/faultmgmt/shell (y/n)? y faultmgmtsp> fmadm repair /SYS/PS0 faultmgmtsp> exit -> reset /SP Are you sure you want to reset /SP (y/n)? y
After the SP has reset, verify that all installed power supplies appear in the list of system devices:
-> ls /SYS
If the problem occurs again after applying this workaround, contact your authorized Oracle Service Provider for further assistance.
In a very small percentage of the time when a system is powered on, ILOM may report a problem with a 12V sensor on one of the processor modules (PM0 or PM1), log a system fault, and abort the power-on sequence.The following is an example of the error message desplayed in the ILOM command line interface if the ILOM start /SYS command fails and the power-on sequence is aborted:
-> start /SYSstart: System faults or hardware configuration prevents power on. Are you sure you want to start /SYS (y/n)? y Are you sure you want to start /SYS (y/n)? y
If your system does not power on using the ILOM start /SYS command, view the ILOM event log:
This issue might be present if you see an error in the ILOM event log that includes PMx/PDx/V_+12V0 (where x is either 0 or 1), such as the following:
1115 Sat Jan 1 12:44:15 2000 IPMI Log minor
ID = b2 : 01/01/2000 : 12:44:15 : Voltage : PM0/PD1/V_+12V0 : Lower Non
-critical going low : reading 0 <= threshold 11.43 Volts
In addition, the ILOM fault management shell indicates that the processor module is faulty.To view a list of faulty components, do the following:
Start the ILOM fault management shell:
Display the list of faulty components:
The following example displays a voltage sensor fault on Processor Module 0 (PM0):
------------------- ------------------------------------ ------------- ------- Time UUID msgid Severity ------------------- ------------------------------------ ------------- ------- 2010-11-12/19:59:33 c55af62d-2da0-48de-f02f-b437146752f7 SPT-8000-DH Critical Fault class : fault.chassis.voltage.fail FRU : /SYS/PM0 (Part Number: 541-4182-08) (Serial Number: 1005LCB-1041HB01A1) Description : A chassis voltage supply is operating outside of the allowable range. Response : The system will be powered off. The chassis-wide service required LED will be illuminated. Impact : The system is not usable until repaired. ILOM will not allow the system to be powered on until repaired. Action : The administrator should review the ILOM event log for additional information pertaining to this diagnosis. Please refer to the Details section of the Knowledge Article for additional information.
Workaround:
Contact your authorized service provider to see if a fix for this issue is available. This issue is fixed in firmware release 8.0.4.b and later. If you have a firmware release earlier than 8.0.4.b, continue with these workaround instructions.
If a fix is not available and you do encounter a power-on failure and an event with one of the PMx/PDx/V_+12V0 sensors, clear the fault using one of the procedures below, and attempt to power on the system again.
Clear the fault using one of the following methods:
To clear the fault using the ILOM CLI:
-> set FRU-name clear_fault_action=true
For example, to clear a fault on Processor Module 0 (PM0):
-> set /SYS/PM0 clear_fault_action=true
To clear the fault using the ILOM fault management shell:
faultmgmtsp> fmadm repair FRU-name
faultmgmtsp> fmadm repair /SYS/PM0 ... faultmgmtsp> exit->
Attempt to power on the system:
-> start /SYS
If the system powers on without failure after you clear the fault, you have encountered CR 7003014, and your system should power on and operate normally.
If the error persists and the system fails to power on, it should be treated as a genuine failure. Contact your authorized service provider for assistance.
