Supported Versions of Oracle Solaris OS, Firmware, and Software
Determining Oracle Solaris 11 OS Package Update Version
Determining Oracle Solaris 10 Patch Revision
Minimum Required Patchset for Oracle Solaris 10 08/11 OS
Minimum Required Patchset for Oracle Solaris 10 09/10 OS
Minimum Required Patchsets and SPARC Bundle for Oracle Solaris 10 10/09 OS
ALOM CMT Compatibility Shell Not Supported
Power Supply Inrush/Input Surge Current Information
Custom nvalias Settings Will Not Change During a System Reconfiguration
Sun Type 6 Keyboards Are Not Supported by SPARC T3 Series Servers
Hardware RAID 1E Not Supported
Enable Flow Control (With a System Reboot)
Enable Flow Control (Without a System Reboot)
Server Panics When Booting From a USB Thumbdrive Attached to the Front USB Ports (CR 6983185)
Copper QSFP Cables Not Supported (CR 6941888)
Error Messages Not Retained After UE and CE Memory Failures (CR 6990058)
Watchdog Timeouts Might Occur Under Very Heavy Load (CR 6994535)
Unrecoverable USB Hardware Errors Occur In Some Circumstances (CR 6995634)
Replace Faulty DIMMs With Uncorrectable Errors (UEs) As Soon As Possible (CR 6996144)
Intermittent Power Supply Faults Occur During Power On (CR 7066165)
Voltage Fault Prevents Host Power-On (CR 7003014)
Static/Dynamic Input/Output Not Currently Supported
Oracle Solaris OS Has Changed How It Specifies Logical Device Names
Oracle Solaris Jumpstart Examples
Interactive Installation Example
The cfgadm -al Command Takes a Long Time to Print Output (CR 6937169)
False nxge Warning Messages (CR 6938085)
Spurious Interrupt Message in System Console (CR 6963563)
The prtpicl Command Does Not Display Drive Information (CR 6963594)
Missing Interrupt Causes USB Hub Hotplug Thread to Hang, Resulting In Process Hangs (CR 6968801)
Long Local Console Delays During Login or Logout of Oracle Solaris (CR 6971884)
Spurious Error Message During Initial Oracle Solaris OS Installation (CR 6971896)
SDIO Policy Violations Might Cause the Primary Domain To Panic During Boot (CR 6983964)
Oracle Enterprise Manager Process Hangs and Becomes Unkillable (CR 6994300)
Intermittent WARNING: ios#, peu# Link Width x8 Link Speed GEN1 Messages (CR 6958263)
Cold Reset Adds One Day to System Time (CR 7127740)
Performing stop /SYS with HOST_COOLDOWN Policy Enabled Generates a Critical Voltage Fault
This section describes issues related to the Oracle Solaris OS in this release.
The SPARC T3-4 server does not support the SDIO feature of Oracle VM Server for SPARC without a fix for 6983964. Please do not use the SDIO feature of Oracle VM Server for SPARC until a fix is available.
See SDIO Policy Violations Might Cause the Primary Domain To Panic During Boot (CR 6983964) for more information.
The Oracle Solaris OS now uses SAS 2.0 World Wide ID (WWID) in place of the tn (target ID) field in logical device names. This change will affect how you identify the target disk when downloading the OS over a network. The following points are key to understanding the impact of this change:
When downloading the OS over a network, you should specify the disk in HDD slot 0 as the download destination. This is the disk that OBP uses as the default boot device.
Before the change to using WWIDs, this disk would be known to the OS by the logical name c0t0d0s0.
With the change, the device identifier for the default boot device is now referred to as c0tWWIDd0s0, where WWID is a hexadecimal value. This WWID value does not map in a predictable way to the physical ID of the disk in HDD slot 0.
Note - By default, the Oracle Solaris OS is installed on the disk in HDD slot 0. If you want to install the OS on a disk in another slot, specify the disk in the preferred slot number.
To reliably specify HDD slot 0 for the OS download operation, you must determine the correspondence between the WWID value for that disk and its physical location. You can do this by running probe-scsi-all and reading the output.
In the probe-scsi-all output, look for the following disk identifiers:
SASDeviceName – This is the disk WWID that the Oracle Solaris OS recognizes.
SASAddress – This is the disk WWID that the OBP references.
PhyNum – This is the physical HDD slot that the disk occupies. It is also expressed as a hexadecimal value.
VolumeDeviceName – This number is the RAID volume's WWID that the Oracle Solaris OS recognizes.
VolumeWWID – This is the RAID volume's WWID that OBP references.
A SPARC T3-4 server has two on-board SAS controllers, each controlling four connected drives. The following example probe-scsi-all output is for a SPARC SPARC T3-4 with eight drives.
ok probe-scsi-all
/pci@700/pci@1/pci@0/pci@0/LSI,sas@0
/pci@400/pci@1/pci@0/pci@0/LSI,sas@0
FCode Version 1.00.54, MPT Version 2.00, Firmware Version 5.00.17.00
Target 9
Target 9
Unit 0 Disk HITACHI H103030SCSUN300G A2A8 585937500 Blocks, 300 GB
Unit 0 Disk HITACHI H103030SCSUN300G A2A8 585937500 Blocks, 300 GBSASDeviceName 5000cca00abcede0 SASAddress 5000cca00abcede1 PhyNum 0
SASDeviceName 5000cca00abc5cc8 SASAddress 5000cca00abc5cc9 PhyNum 0Target aTarget aUnit 0 Disk HITACHI H103030SCSUN300G A2A8 585937500 Blocks, 300 GB
SASDeviceName 5000cca00abaf620 SASAddress 5000cca00abaf621 PhyNum 1
SASDeviceName 5000cca00abc51a8 SASAddress 5000cca00abc51a9 PhyNum 1Target b
Target bUnit 0 Disk HITACHI H103030SCSUN300G A2A8 585937500 Blocks, 300 GBUnit 0 Disk HITACHI H103030SCSUN300G A2A8 585937500 Blocks, 300 GBSASDeviceName 5000cca00abcec4c SASAddress 5000cca00abcec4d PhyNum 2
SASDeviceName 5000cca00abce89c SASAddress 5000cca00abce89d PhyNum 2
Target c
Target cUnit 0 Disk HITACHI H103030SCSUN300G A2A8 585937500 Blocks, 300 GB
Unit 0 Disk HITACHI H103030SCSUN300G A2A8 585937500 Blocks, 300 GBSASDeviceName 5000cca00abc5218 SASAddress 5000cca00abc5219 PhyNum 3SASDeviceName 5000cca00abc5354 SASAddress 5000cca00abc5355 PhyNum 3
/pci@400/pci@1/pci@0/pci@8/pci@0/usb@0,2/hub@2/hub@3/storage@2
{0} ok
Unit 0 Removable Read Only device AMI Virtual CDROM 1.00
The following probe-scsi-all example output shows a RAID configuration. The RAID volume's VolumeDeviceName is 3c2f959213c8a292.
ok probe-scsi-all
Target 9
Target a
Target 37e Volume 0
Unit 0 Disk LSI Logical Volume 3000 1167966208 Blocks, 597 GB
VolumeDeviceName 3c2f959213c8a292 VolumeWWID 0c2f959213c8a292
Target 9
Target a
Target b
Target c
{0} ok
The following Oracle Solaris Jumpstart profile example shows how to use the WWID syntax when installing the OS on a specific disk drive. The SASDeviceName is taken from the previous six-drive configuration listing.
Note - The Oracle Solaris syntax rules require all alpha characters in the WWID be capitalized.
# install_type flash_install boot_device c0t5000C5001CB4A637d0s0 preserve archive_location nfs 129.148.94.249:/export/install/media/solaris/builds/s10u9/flar/latest.flar # Disk layouts # partitioning explicit filesys rootdisk.s0 free / filesys rootdisk.s1 8192 swap
The following Oracle Solaris Jumpstart profile example shows how to use the WWID syntax when installing the OS on a RAID volume. The VolumeDeviceName is taken from the previous RAID probe-scsi-all example.
# install_type flash_install boot_device c0t3CE534E42C02A3C0d0s0 preserve archive_location nfs 129.148.94.249:/export/install/media/solaris/builds/s10u9/flar/latest.flar # Disk layouts # partitioning explicit filesys rootdisk.s0 free / filesys rootdisk.s1 8192 swap
In an interactive install, you will be asked to specify one or more disks as the targets for the OS installation. The purpose of this step is to ensure that enough disk capacity is being provided for the installation. For this step, specify the disk with the WWID value corresponding to the drive on which you want to install the software.
These WWID values are illustrated in the following interactive example, which is based on the same six-disk environment used in the previous examples. The drive selected as the install target is located in HDD slot 0—the default OBP location.
Note - If some other disk is preferred, you can specify it instead of the one in HDD slot 0.
_ Select Disks_________________________________________________________________ On this screen you must select the disks for installing Solaris software. Start by looking at the Suggested Minimum field; this value is the approximate space needed to install the software you've selected. Keep selecting disks until the Total Selected value exceeds the Suggested Minimum value. NOTE: ** denotes current boot disk Disk Device Available Space ============================================================================= [ ] c0t5000CCA00ABAF620d0 286090 MB [X] ** c0t5000CCA00ABC51A8d0 286090 MB ______________________________________________________________________________ [ ] c0t5000CCA00ABC5218d0 286090 MB[ ] c0t5000CCA00ABC5354d0 286090 MB Esc-2_Continue F3_Go Back F4_Edit F5_Exit F6_Help[ ] c0t5000CCA00ABC5CC8d0 286090 MB [ ] c0t5000CCA00ABCE89Cd0 286090 MB [ ] c0t5000CCA00ABCEC4Cd0 286090 MB [ ] c0t5000CCA00ABCEDE0d0 286090 MB Total Selected: 286090 MB Suggested Minimum: 5009 MB
The cfgadm(1M) command for configuring or unconfiguring hot-plug devices takes a long time to complete. For example, the cfgadm -al command could take more than five minutes before it lists the attachment points for all the hot-plug devices.
Workaround:
Use the hotplug(1M) command to manage PCIe hotplug devices.
Note - The workaround using the hotplug command instead of cfgadm -al only works for PCI devices.
Use the hotplug list -l command to list the status of all hot-plug PCIe slots. For example:
# hotplug list -l | grep PCI-EM /pci@400/pci@1/pci@0/pci@4 [PCI-EM2] (EMPTY) /pci@400/pci@2/pci@0/pci@1 [PCI-EM0] (EMPTY) /pci@400/pci@2/pci@0/pci@2 [PCI-EM1] (EMPTY)/pci@400/pci@2/pci@0/pci@3 [PCI-EM3] (ENABLED) /pci@500/pci@1/pci@0/pci@1 [PCI-EM8] (EMPTY) /pci@500/pci@1/pci@0/pci@2 [PCI-EM10] (ENABLED) /pci@500/pci@2/pci@0/pci@2 [PCI-EM9] (ENABLED) /pci@500/pci@2/pci@0/pci@3 [PCI-EM11] (EMPTY) /pci@600/pci@1/pci@0/pci@4 [PCI-EM4] (EMPTY) /pci@600/pci@1/pci@0/pci@5 [PCI-EM6] (ENABLED) /pci@600/pci@2/pci@0/pci@0 [PCI-EM7] (EMPTY) /pci@600/pci@2/pci@0/pci@5 [PCI-EM5] (EMPTY) /pci@700/pci@1/pci@0/pci@4 [PCI-EM14] (EMPTY) /pci@700/pci@2/pci@0/pci@3 [PCI-EM12] (ENABLED) /pci@700/pci@2/pci@0/pci@4 [PCI-EM13] (EMPTY) /pci@700/pci@2/pci@0/pci@5 [PCI-EM15] (EMPTY)
Use the hotplug disable command to disable a PCIe card.
For example, to disable the EM card in PCI-EM3 and confirm that it is no longer enabled:
# hotplug disable /pci@400/pci@2/pci@0/pci@3 PCI-EM3 # hotplug list -l | grep PCI-EM3/pci@400/pci@2/pci@0/pci@3 [PCI-EM3] (POWERED)
Use the hotplug poweroff command to power off a PCIe card.
For example, to power off the EM card in PCI-EM3:
# hotplug poweroff /pci@400/pci@2/pci@0/pci@3 PCI-EM3 # hotplug list -l | grep PCI-EM3/pci@400/pci@2/pci@0/pci@3 [PCI-EM3] (PRESENT)
You may now physically remove the EM card.
Use the hotplug list command to verify that a card is removed.
For example:
# hotplug list -l | grep PCI-EM ... /pci@400/pci@2/pci@0/pci@3 [PCI-EM3] (EMPTY) ...
Use the hotplug poweron command to power on a PCIe card.
For example, to power on the EM card in PCI-EM3 and confirm that it has moved to the POWERED state:
# hotplug poweron /pci@400/pci@2/pci@0/pci@3 PCI-EM3 # hotplug list -l | grep PCI-EM3/pci@400/pci@2/pci@0/pci@3 [PCI-EM3] (POWERED)
Use the hotplug enable command to enable a PCIe card.
For example, to enable the EM card in PCI-EM3 and confirm that it has moved to the ENABLED state:
# hotplug enable /pci@400/pci@2/pci@0/pci@3 PCI-EM3 # hotplug list -l | grep PCI-EM3/pci@400/pci@2/pci@0/pci@3 [PCI-EM3] (ENABLED)
Note - For more information about the hotplug command, see the hotplug(1M) man page.
During the normal operation of your server, you might see warning messages like the following in the system console:
date time machinename nxge: [ID 752849 kern.warning] WARNING: nxge0 : nxge_hio_init: hypervisor services version 2.0
These messages are not true warning messages. These Gigabit Ethernet driver (nxge) messages display the version number of the hypervisor since the driver can operate on multiple hypervisor versions. These messages should labeled as a INFO or NOTICE messages instead of WARNING messages.
Workaround:
You can safely ignore these messages.
During the normal operation of the server, and when running the Oracle VTS system exerciser, you might see the following message in the system console:
date time hostname px: [ID 781074 kern.warning] WARNING: px0: spurious interrupt from ino 0x4 date time hostname px: [ID 548919 kern.info] ehci-0#0 date time hostname px: [ID 100033 kern.info]
Workaround:
You can safely ignore this message.
On previous systems, the prtpicl -v command displayed the state, location, and device paths for system drives under a disk_discovery heading. On SPARC T3 systems, the prtpicl command no longer displays this drive information.
Workaround:
Use the OpenBoot probe-scsi-all command. For example output, see Oracle Solaris OS Has Changed How It Specifies Logical Device Names.
When running the Oracle VTS software on SPARC T3 series servers, it is possible (although rare) for a Oracle VTS test to hang. If this test process hangs, the hung process might cause other processes and commands to hang, including the fault management configuration tool (fmadm) and the print system configuration command (prtconf). These hung processes cannot be killed.
Workaround:
Reboot the system. If the problem repeats, contact your service representative for assistance. Avoid running the Oracle VTS software in production environments.
You might experience long latency times (up to three minutes) when logging in or logging out of the Solaris OS using a local console or local keyboard, mouse and monitor.
Workaround:
Use a network connection to access the system, and comment out the lines containing USB console device names (/dev/usb/*) in the /etc/logindevperm configuration file:
# /dev/console 0600 /dev/usb/hid[0-9]+ # hid devices should have the same permission with conskbd and consms # /dev/console 0600 /dev/usb/[0-9a-f]+[.][0-9a-f]+/[0-9]+/* driver=scsa2usb,usb_mid,usbprn,ugen #libusb/ugen devices ...
The miniroot is a bootable root file system that includes the minimum Oracle Solaris OS software required to boot the server and configure the OS. The miniroot runs only during the installation process.When the server boots the miniroot for the initial configuration, you might see the following messages in the system console:
Fatal server error: InitOutput: Error loading module for /dev/fb giving up. /usr/openwin/bin/xinit: Network is unreachable (errno 128): unable to connect to X server /usr/openwin/bin/xinit: No such process (errno 3): Server error.
The messages indicate that the Xsun server in the Oracle Solaris OS miniroot cannot find a supported driver for the AST graphics device in the service processor. These messages are fully expected, as the miniroot contains only the Xsun environment, and the AST framebuffer (astfb) is supported only in the Xorg environment. The Xorg environment is included in the installed system, so the graphics device may be used when running the installed Oracle Solaris OS.
Workaround:
If you have a system using Oracle VM Server for SPARC and you have one or more guests configured to use the Static/Direct Input/Output (SDIO) feature, it is possible for the primary domain to panic when the system has just been powered on and the primary domain is booting.
The panic message appears similar to the following:
panic[cpu6]/thread=2a101283ca0: Fatal error has occured in: PCIe fabric.(0x1)(0x43) 000002a101283700 px:px_err_panic+1ac (702cec00, 7bf57000, 43, 2a1012837b0, 1, 0) %l0-3: 0000009980001602 00000000702cf000 0000000000000000 0000000000000001 %l4-7: 0000000000000000 00000000018af000 0000000000000001 0000000000000000 000002a101283810 px:px_err_fabric_intr+1c0 (6002c594480, 1, 702cf000, 1, 43, 200) %l0-3: 0000000000000200 0000000000000001 00000000702cf2c0 00000000702cf000 %l4-7: 00000000702cf2b8 00000000702cf000 0000000000000001 000006002c4d4790 000002a101283980 px:px_msiq_intr+1e8 (6002c447bf0, 30002df1908, 7bf495d0, 0, 1, 6002c6f01f0) %l0-3: 000006002c639220 000006002b561e40 0000030002df1908 0000000000000000 %l4-7: 0000000000000000 0000000003a60000 000002a101283a80 0000000000000030
This problem can occur while the primary domain is booting; it does not happen to already running systems.
Workaround:
There is no workaround currently available for this issue. Please contact your authorized service provider for a fix.
When rebooting the server after a failed or disabled CPU reconfigures back to the host, the onboard Gigabit Ethernet connections will not connect to network. The following example messages will display on the system console:
igb0: DL_ATTACH_REQ failed: DL_SYSERR (errno 22) igb0: DL_BIND_REQ failed: DL_OUTSTATE igb0: DL_PHYS_ADDR_REQ failed: DL_OUTSTATE igb0: DL_UNBIND_REQ failed: DL_OUTSTATE Failed to plumb IPv4 interface(s): igb0
Workaround:
Reboot the server two additional times. If the problem persists, contact your service representative for assistance.
When a CPU thread faults, the record of that fault is retained when the system reboots, even if the cause of the fault has been corrected. The presence of this record will cause the CPU thread to be off-lined when the system reboots.
Recovery:
Enable the faulted thread(s) explicitly.
The Oracle Enterprise Manager Java process can hang and become unkillable on the server. When the Enterprise Manager process hangs, it continues to listen on its Web UI port, which makes the process unkillable. This problem has been seen on servers running both the Java SE 5.0 version that is bundled with Oracle Database software and with the most recent downloadable Java SE 6 Update 22 version.
Workaround:
If you installed the Oracle Solaris 10 10/09 OS and the Solaris 10 9/10 Patch Bundle on the server, the 10/1 Gigabit Ethernet (nxge) driver will not attach to 10 GbE devices.
Workaround:
Add the following line to the /etc/driver_aliases file:
nxge "SUNW,niusl-kt"
Then reboot the server and configure the Gigabit Ethernet devices normally.
Under certain circumstances, a memory error can cause an internal error in the FMA diagnosis engine that prevents proper diagnosis of the memory error.This failure might be present if fmadm faulty command output includes the fault FMD-8000-2K in the list of faulty components.
For example:
# fmadm faulty ... --------------- ------------------------------------ ----------------------- TIME EVENT-ID MSG-ID SEVERITY--------------- ------------------------------------ ----------------------- Nov 16 12:02:01 865e378b-27a5-ebf7-c550-e34179d57241 FMD-8000-2K Minor Host : xxxxxxx Platform : ORCL,SPARC-T3-4 Chassis_id : Product_sn : Fault class : defect.sunos.fmd.module Affects : fmd:///module/eft faulted and taken out of service FRU : None faulty Description : A Solaris Fault Manager component has experienced an error that required the module to be disabled. Refer to http://sun.com/msg/FMD-8000-2K for more information. Response : The module has been disabled. Events destined for the module will be saved for manual diagnosis. Impact : Automated diagnosis and response for subsequent events associated with this module will not occur. Action : Use fmdump -v -u <EVENT-ID> to locate the module. Use fmadm reset <module> to reset the module.
To confirm that you have encountered CR 70000649, use the fmdump -eV command and look for an ereport.fm.fmd.module ereport that contains the words “eft's allocation of XX bytes exceeds module memory limit” where XX is any number.
For example:
# fmdump -eV... Nov 16 2010 12:02:01.052061745 ereport.fm.fmd.module nvlist version: 0 version = 0x0 class = ereport.fm.fmd.module detector = (embedded nvlist) nvlist version: 0 version = 0x0 scheme = fmd authority = (embedded nvlist) nvlist version: 0 version = 0x0 product-id = ORCL,SPARC-T3-4 server-id = xxxxxxxx (end authority) mod-name = eft mod-version = 1.16 (end detector) ena = 0x3ddfe7a2c3f07401 msg = eft's allocation of 20 bytes exceeds module memory limit (10485756) __ttl = 0x1 __tod = 0x4ce2e339 0x31a6631
Workaround:
If the fmdump -eV output indicates that you have encountered CR 7000649, contact your authorized service provider to see if a fix is available.
Schedule a reboot of the server with diagnostics enabled to allow POST to attempt to find the suspect DIMM.
After halting all of the Solaris sessions on your system, complete the following:
Power off the system:
-> stop /SYS
Set keyswitch_state to Diag:
-> show /SYS keyswitch_state /SYS Properties: keyswitch_state = Normal -> set /SYS keyswitch_state=diag Set 'keyswitch_state' to 'diag' -> show /SYS keyswitch_state Properties:/SYSkeyswitch_state = Diag
Note - This option overrides previously set values of diagnostic properties.
Power on the server:
-> start /SYS Are you sure you want to start /SYS (y/n)? yStarting /SYS
After the power-on sequence is complete, enter the ILOM Fault Management shell and use the ILOM show faulty command to look for any faulty DIMMs.
Start the fault management shell:
-> start /SP/faultmgmt/shell Are you sure you want to start /SP/faultmgmt/shell (y/n)? y
Display the list of faulty components:
faultmgmtsp> fmadm faulty
Replace any faulty DIMMs that are reported. If no faulty DIMMs are reported, contact your authorized service provider for further assistance.
