Supported Versions of Oracle Solaris OS, Firmware, and Software
Determining Oracle Solaris 11 OS Package Update Version
Determining Oracle Solaris 10 Patch Revision
Minimum Required Patchset for Oracle Solaris 10 08/11 OS
Minimum Required Patchset for Oracle Solaris 10 09/10 OS
Minimum Required Patchsets and SPARC Bundle for Oracle Solaris 10 10/09 OS
ALOM CMT Compatibility Shell Not Supported
Power Supply Inrush/Input Surge Current Information
Custom nvalias Settings Will Not Change During a System Reconfiguration
Sun Type 6 Keyboards Are Not Supported by SPARC T3 Series Servers
Hardware RAID 1E Not Supported
Enable Flow Control (With a System Reboot)
Enable Flow Control (Without a System Reboot)
Server Panics When Booting From a USB Thumbdrive Attached to the Front USB Ports (CR 6983185)
Copper QSFP Cables Not Supported (CR 6941888)
Error Messages Not Retained After UE and CE Memory Failures (CR 6990058)
Watchdog Timeouts Might Occur Under Very Heavy Load (CR 6994535)
Unrecoverable USB Hardware Errors Occur In Some Circumstances (CR 6995634)
Replace Faulty DIMMs With Uncorrectable Errors (UEs) As Soon As Possible (CR 6996144)
Intermittent Power Supply Faults Occur During Power On (CR 7066165)
Voltage Fault Prevents Host Power-On (CR 7003014)
Static/Dynamic Input/Output Not Currently Supported
Oracle Solaris OS Has Changed How It Specifies Logical Device Names
Oracle Solaris Jumpstart Examples
Interactive Installation Example
The cfgadm -al Command Takes a Long Time to Print Output (CR 6937169)
False nxge Warning Messages (CR 6938085)
Spurious Interrupt Message in System Console (CR 6963563)
The prtpicl Command Does Not Display Drive Information (CR 6963594)
Missing Interrupt Causes USB Hub Hotplug Thread to Hang, Resulting In Process Hangs (CR 6968801)
Long Local Console Delays During Login or Logout of Oracle Solaris (CR 6971884)
Spurious Error Message During Initial Oracle Solaris OS Installation (CR 6971896)
SDIO Policy Violations Might Cause the Primary Domain To Panic During Boot (CR 6983964)
Oracle Enterprise Manager Process Hangs and Becomes Unkillable (CR 6994300)
This section describes issues related to the system firmware.
When your server powers on to the OpenBoot PROM (OBP), you might see warning messages like the following in the system console:
WARNING: ios0, peu0 Link Width x8 Link Speed GEN1.
Workaround:
You can safely ignore these messages.
The LSI Corporation sas2flash utility fails when there are six or more Sun Storage 6 Gb SAS RAID PCIe HBAs, External, installed in the system. For example, when attempting to list the HBAs using the sas2flash -listall command, you might see the following error message:
6 SAS2008(??) ERROR: Failed to Upload Image! ----------- ---------- ERROR: Failed to Upload Image!
Workaround:
Install five or less Sun Storage 6 Gb SAS RAID PCIe HBAs, External, in the system.
Your Oracle VM Server for SPARC 2.0 system might encounter one of the following problems if you reboot the root domain after adding a PCIe end-point device to a guest domain:
Experience a hypervisor abort and shut down
Fail to return to the OpenBoot PROM
Fail to return to the Oracle Solaris OS
These problems only occur if you did not start the guest domain after adding the PCIe device. By not starting the guest domain, previously configured virtual interfaces might not have been properly cleaned up.
Workaround:
If these problems occur, restart the system. To avoid these problems, start a guest domain after adding an I/O resource to it. If you do not want the domain to be active at this time, stop the guest domain after it has been started.
Note - This issue is fixed in System Firmware version 8.1.4.e.
After a cold reset, the server might add one day to the Oracle Solaris OS date and time. This possible date change will only occur on the first cold reset after January 1, 2012. Once you set the correct date using the Oracle Solaris OS date(1) command, the corrected date and time will persist across future resets.
A cold reset is when you halt the OS and restart the service processor (SP). For example, you can use one of the following Oracle Solaris OS commands to halt the OS:
# shutdown -g0 -i0 -y
# uadmin 1 6
# init 5
# poweroff
Then, at the ILOM prompt, use the following commands to reset the host:
-> stop /SYS . . . -> start /SYS
Refer to the service manual, the administration guide, and the Oracle Solaris OS documentation for more information.
Workaround:
After the first cold reset of the system, verify that the system date and time are correct. If the date has been impacted by this issue, use the Oracle Solaris OS date(1) command to set the correct date and time.
For example, to set the date and time to be February 26, 9:00am, 2012, type:
# date 022609002012
Refer to the date(1) man page and the Oracle Solaris OS documentation for more information.
By default, the HOST_COOLDOWN policy is disabled in the SP policy list, as shown by the following ILOM command:
-> ls /SP/policy /SP/policy Targets: Properties: HOST_AUTO_POWER_ON = disabled HOST_COOLDOWN = disabled HOST_LAST_POWER_STATE = disabled HOST_POWER_ON_DELAY = disabled PARALLEL_BOOT = enabled Commands: cd set show
If you change this value to enabled, you will encounter a fault.chassis.voltage.fail fault when you power off your system. This fault prevents you from powering your system on again until it is cleared.
This fault is in the event list in the ILOM command-line interface. For example:
-> show /SP/logs/event/list 24756 Wed Nov 24 11:23:36 2010 Fault Fault critical Fault detected at time = Wed Nov 24 11:23:36 2010. The suspect component: /SYS/MB has fault.chassis.voltage.fail with probability=100. Refer to http://www.sun.com/msg/SPT-8000-DH for details. 24755 Wed Nov 24 11:23:36 2010 System Log minor Host: Solaris powering down 24754 Wed Nov 24 11:23:24 2010 System Log minor Host: Host stopped
Workaround:
Disable the HOST_COOLDOWN policy:
-> set /SP/policy HOST_COOLDOWN=disabled Set 'HOST_COOLDOWN' to 'disabled'
Clear the fault:
-> set /SYS/MB clear_fault_action=true Are you sure you want to clear /SYS/MB (y/n)? ySet 'clear_fault_action' to 'true'
Restart the system:
-> start /SYS
