Save enables you to save changes made to the current audio file. Click SELECT on the Save menu item to save the file.
If a file has been named and previously saved, clicking SELECT on Save replaces the old copy with the current version.
If the audio data has not been saved previously, or has not yet been edited, the Audio Tool: Save As window is displayed. The Save item is dimmed if no audio file is loaded (following a New operation, for example) or if the audio file has not been edited since a previous Save.
