This topic provides instructions on how to install additional JBI based components after the initial installation. It assumes that you have successfully installed Java CAPS, the Sun Java System Application Server, and the NetBeans IDE.
To start the Repository and the NetBeans IDE navigate to the base directory where you installed Java CAPS, and start the appropriate executable files.
To install additional JBI based Java CAPS components:
From the NetBeans IDE menu bar choose Tools and then Plugins.
On the Plugins page, choose the Settings tab.
From the Configuration of Update Centers pane select the type of components you want to install, choose the Available Plugins tab, and then select the modules you want in install.
To select all, right-click any of the entries and select Check All.
To begin the installation, click Install.
When the NetBeans IDE Installer appears, click Next, accept the license, and click Install.
This page lists the JBI based Java CAPS components you are installing.
Ignore any “validation” or “unsigned” warnings and continue with the installation.
When the installation completes, click Finish and then close the Plugins dialog box.
You are now ready to continue using Java CAPS.
