The Oracle scripts that come with the solution create a user identified as usa. They are located in the Solutions\NB\MI\project\USAPatient\sca\source\DatabaseScript directory.
As a SYSDBA user run the createuser-usa.sql script.
As the usa user, with a password of usa, run the following scripts.
Run the create.sql script first.
create.sql
codelist.sql
systems.sql
createIndexes.sql
createUserCodeData.sql
