When the link-editor is generating an executable output file, the link-editor's default behavior is to terminate the link-edit with an appropriate error message should any symbols remain undefined. A symbol remains undefined when a symbol reference in a relocatable object is never matched to a symbol definition:
$ cat main.c
extern int foo();
main()
return (foo());
$ cc -o prog main.c
Undefined first referenced
symbol in file
foo main.o
ld: fatal: Symbol referencing errors. No output written to prog
In a similar manner, a symbol reference within a shared object that is never matched to a symbol definition when the shared object is being used to build a dynamic executable, will also result in an undefined symbol:
$ cat foo.c
extern int bar;
foo()
return (bar);
$ cc -o libfoo.so -G -K pic foo.c
$ cc -o prog main.c -L. -lfoo
symbol in file
bar ./libfoo.so
If you want to allow undefined symbols, as in cases like the previous example, then the default fatal error condition can be suppressed by using the link-editor's -z nodefs option.
Take care when using the -z nodefs option. If an unavailable symbol reference is required during the execution of a process, a fatal runtime relocation error will occur. Although this error can be detected during the initial execution and testing of an application, more complex execution paths can result in this error condition taking much longer to detect, which can be time consuming and costly.
Symbols can also remain undefined when a symbol reference in a relocatable object is bound to a symbol definition in an implicitly defined shared object. For example, continuing with the files main.c and foo.c used in the previous example:
$ cat bar.c
int bar = 1;
$ cc -o libbar.so -R. -G -K pic bar.c -L. -lfoo
$ ldd libbar.so
libfoo.so => ./libfoo.so
$ cc -o prog main.c -L. -lbar
symbol in file
foo main.o (symbol belongs to implicit \
dependency ./libfoo.so)
Here prog is being built with an explicit reference to libbar.so, and because libbar.so has a dependency on libfoo.so, an implicit reference to libfoo.so from prog is established.
Because main.c made a specific reference to the interface provided by libfoo.so, then prog really has a dependency on libfoo.so. However, only explicit shared object dependencies are recorded in the output file being generated. Thus, prog will fail to run if a new version of libbar.so is developed that no longer has a dependency on libfoo.so.
For this reason, bindings of this type are deemed fatal, and the implicit reference must be made explicit by referencing the library directly during the link-edit of prog (the required reference is hinted at in the fatal error message shown in this example).
The Sun C compiler provides the -xarch=v9 option for compiling 64-bit SPARCV9 objects. The linker has no explicit option telling it to perform a 64-bit link-edit; rather it examines the first object that it is given on the command line and uses its ELF type to determine how to proceed.
