Field names in the following table tell whether the relocation type checks for overflow. A calculated relocation value can be larger than the intended field, and a relocation type can verify (V) the value fits or truncate (T) the result. As an example, V-simm13 means that the computed value can not have significant, nonzero bits outside the simm13 field.
Name |
Value |
Field |
Calculation |
R_SPARC_NONE |
0 |
None |
None |
R_SPARC_8 |
1 |
V-byte8 |
S + A |
R_SPARC_16 |
2 |
V-half16 |
S + A |
R_SPARC_32 |
3 |
V-word32 |
S + A |
R_SPARC_DISP8 |
4 |
V-byte8 |
S + A - P |
R_SPARC_DISP16 |
5 |
V-half16 |
S + A - P |
R_SPARC_DISP32 |
6 |
V-disp32 |
S + A - P |
R_SPARC_WDISP30 |
7 |
V-disp30 |
(S + A - P) >> 2 |
R_SPARC_WDISP22 |
8 |
V-disp22 |
(S + A - P) >> 2 |
R_SPARC_HI22 |
9 |
V-imm22 |
(S + A) >> 10 |
R_SPARC_22 |
10 |
V-imm22 |
S + A |
R_SPARC_13 |
11 |
V-simm13 |
S + A |
R_SPARC_LO10 |
12 |
T-simm13 |
(S + A) & 0x3ff |
R_SPARC_GOT10 |
13 |
T-simm13 |
G & 0x3ff |
R_SPARC_GOT13 |
14 |
V-simm13 |
G |
R_SPARC_GOT22 |
15 |
T-simm22 |
G >> 10 |
R_SPARC_PC10 |
16 |
T-simm13 |
(S + A - P) & 0x3ff |
R_SPARC_PC22 |
17 |
V-disp22 |
(S + A - P) >> 10 |
R_SPARC_WPLT30 |
18 |
V-disp30 |
(L + A - P) >> 2 |
R_SPARC_COPY |
19 |
None |
None |
R_SPARC_GLOB_DAT |
20 |
V-xword64 |
S + A |
R_SPARC_JMP_SLOT |
21 |
None |
See R_SPARC_JMP_SLOT, |
R_SPARC_RELATIVE |
22 |
V-xword64 |
B + A |
R_SPARC_UA32 |
23 |
V-word32 |
S + A |
R_SPARC_PLT32 |
24 |
V-word32 |
L + A |
R_SPARC_HIPLT22 |
25 |
T-imm22 |
(L + A) >> 10 |
R_SPARC_LOPLT10 |
26 |
T-simm13 |
(L + A) & 0x3ff |
R_SPARC_PCPLT32 |
27 |
V-disp32 |
L + A - P |
R_SPARC_PCPLT22 |
28 |
V-disp22 |
(L + A - P) >> 10 |
R_SPARC_PCPLT10 |
29 |
V-simm13 |
(L + A - P) & 0x3ff |
R_SPARC_10 |
30 |
V-simm10 |
S + A |
R_SPARC_11 |
31 |
V-simm11 |
S + A |
R_SPARC_64 |
32 |
V-xword64 |
S + A |
R_SPARC_OLO10 |
33 |
V-simm13 |
((S + A) & 0x3ff) + O |
R_SPARC_HH22 |
34 |
V-imm22 |
(S + A) >> 42 |
R_SPARC_HM10 |
35 |
T-simm13 |
((S + A) >> 32) & 0x3ff |
R_SPARC_LM22 |
36 |
T-imm22 |
(S + A) >> 10 |
R_SPARC_PC_HH22 |
37 |
V-imm22 |
(S + A - P) >> 42 |
R_SPARC_PC_HM10 |
38 |
T-simm13 |
((S + A - P) >> 32) & 0x3ff |
R_SPARC_PC_LM22 |
39 |
T-imm22 |
(S + A - P) >> 10 |
R_SPARC_WDISP16 |
40 |
V-d2/disp14 |
(S + A - P) >> 2 |
R_SPARC_WDISP19 |
41 |
V-disp19 |
(S + A - P) >> 2 |
R_SPARC_7 |
43 |
V-imm7 |
(S + A) & 0x7f |
R_SPARC_5 |
44 |
V-imm5 |
(S + A) & 0x1f |
R_SPARC_6 |
45 |
V-imm6 |
(S + A) & 0x3f |
R_SPARC_DISP64 |
46 |
V-xword64 |
S + A - P |
R_SPARC_PLT64 |
47 |
V-xword64 |
L + A |
R_SPARC_HIX22 |
48 |
V-imm22 |
((S + A) ^ 0xffffffffffffffff) >> 10 |
R_SPARC_LOX10 |
49 |
T-simm13 |
((S + A) & 0x3ff) | 0x1c00 |
R_SPARC_H44 |
50 |
V-imm22 |
(S + A) >> 22 |
R_SPARC_M44 |
51 |
T-imm10 |
((S + A) >> 12) & 0x3ff |
R_SPARC_L44 |
52 |
T-imm13 |
(S + A) & 0xfff |
R_SPARC_REGISTER |
53 |
V-xword64 |
S + A |
R_SPARC_UA64 |
54 |
V-xword64 |
S + A |
R_SPARC_UA16 |
55 |
V-half16 |
S + A |
Some relocation types have semantics beyond simple calculation:
This relocation type resembles R_SPARC_LO10, except that it refers to the address of the symbol's global offset table entry and additionally instructs the link-editor to build a global offset table.
This relocation type resembles R_SPARC_13, except that it refers to the address of the symbol's global offset table entry and additionally instructs the link-editor to build a global offset table.
This relocation type resembles R_SPARC_22, except that it refers to the address of the symbol's global offset table entry and additionally instructs the link-editor to build a global offset table.
This relocation type resembles R_SPARC_WDISP30, except that it refers to the address of the symbol's procedure linkage table entry and additionally instructs the link-editor to build a procedure linkage table.
The link-editor creates this relocation type for dynamic linking. Its offset member refers to a location in a writable segment. The symbol table index specifies a symbol that should exist both in the current object file and in a shared object. During execution, the runtime linker copies data associated with the shared object's symbol to the location specified by the offset. See "Copy Relocations" for more details.
This relocation type resembles R_SPARC_64, except that it sets a global offset table entry to the address of the specified symbol. The special relocation type allows you to determine the correspondence between symbols and global offset table entries.
The link-editor creates this relocation type for dynamic linking. Its offset member gives the location of a procedure linkage table entry. The runtime linker modifies the procedure linkage table entry to transfer control to the designated symbol address.
The link-editor creates this relocation type for dynamic linking. Its offset member gives the location within a shared object that contains a value representing a relative address. The runtime linker computes the corresponding virtual address by adding the virtual address at which the shared object is loaded to the relative address. Relocation entries for this type must specify 0 for the symbol table index.
This relocation type resembles R_SPARC_32, except that it refers to an unaligned word. That is, the word to be relocated must be treated as four separate bytes with arbitrary alignment, not as a word aligned according to the architecture requirements.
This relocation type resembles R_SPARC_LO10, except that an extra offset is added to make full use of the 13-bit signed immediate field.
This relocation type is used by the assembler when it sees an instruction of the form "imm22-instruction ... %hh(absolute) ...".
This relocation type is generated by the assembler when it sees an instruction of the form "simm13-instruction ... %hm(absolute) ..."
This relocation type is used by the assembler when it sees an instruction of the form "imm22-instruction ... %lm(absolute) ...". This resembles R_SPARC_HI22, except it truncates rather than validates.
This relocation type is used by the assembler when it sees an instruction of the form "imm22-instruction ... %hh(pc-relative) ...".
This relocation type is generated by the assembler when it sees an instruction of the form "simm13-instruction ... %hm(pc-relative) ...".
This relocation type is used by the assembler when it sees an instruction of the form "imm22-instruction ... %lm(pc-relative) ...". This resembles R_SPARC_PC22, except that it truncates rather than validates.
This relocation type is used by the assembler for 7 bit software trap numbers.
This relocation type is used with R_SPARC_LOX10 for executables that will be confined to the uppermost 4GB of the 64-bit address space. Similar to R_SPARC_HI22, but supplies ones complement of linked value.
Used with R_SPARC_HIX22. Similar to R_SPARC_LO10, but always sets bits 10..12 of the linked value.
This relocation type is used by the assembler when it sees an instruction of the form "imm44-instruction ... %h44(absolute) ..".
This relocation type is generated by the assembler when it sees an instruction of the form "imm44-instruction ... %m44(absolute) ...".
This relocation type is used with the R_SPARC_H44 and R_SPARC_M44 relocation types to generate a 44-bit absolute addressing model. The assembler will generate this type when it sees an instruction of the form "imm44-instruction ... %l44(absolute) ...".
This relocation type is used to initialize a register symbol. Its offset member contains the register number to be initialized. There must be a corresponding register symbol for this register of type SHN_ABS.
