Name |
Value |
Field |
Calculation |
R_386_NONE |
0 |
none |
none |
R_386_32 |
1 |
word32 |
S + A |
R_386_PC32 |
2 |
word32 |
S + A - P |
R_386_GOT32 |
3 |
word32 |
G + A |
R_386_PLT32 |
4 |
word32 |
L + A - P |
R_386_COPY |
5 |
none |
none |
R_386_GLOB_DAT |
6 |
word32 |
S |
R_386_JMP_SLOT |
7 |
word32 |
S |
R_386_RELATIVE |
8 |
word32 |
B + A |
R_386_GOTOFF |
9 |
word32 |
S + A - GOT |
R_386_GOTPC |
10 |
word32 |
GOT + A - P |
R_386_32PLT |
11 |
word32 |
L + A |
Some relocation types have semantics beyond simple calculation:
This relocation type computes the distance from the base of the global offset table to the symbol's global offset table entry. It also instructs the link-editor to build a global offset table.
This relocation type computes the address of the symbol's procedure linkage table entry and instructs the link-editor to build a procedure linkage table.
The link-editor creates this relocation type for dynamic linking. Its offset member refers to a location in a writable segment. The symbol table index specifies a symbol that should exist both in the current object file and in a shared object. During execution, the runtime linker copies data associated with the shared object's symbol to the location specified by the offset. See "Copy Relocations".
This relocation type is used to set a global offset table entry to the address of the specified symbol. The special relocation type lets one determine the correspondence between symbols and global offset table entries.
The link-editor creates this relocation type for dynamic linking. Its offset member gives the location of a procedure linkage table entry. The runtime linker modifies the procedure linkage table entry to transfer control to the designated symbol address.
The link-editor creates this relocation type for dynamic linking. Its offset member gives the location within a shared object that contains a value representing a relative address. The runtime linker computes the corresponding virtual address by adding the virtual address at which the shared object is loaded to the relative address. Relocation entries for this type must specify 0 for the symbol table index.
This relocation type computes the difference between a symbol's value and the address of the global offset table. It also instructs the link-editor to build the global offset table.
This relocation type resembles R_386_PC32, except it uses the address of the global offset table in its calculation. The symbol referenced in this relocation normally is _GLOBAL_OFFSET_TABLE_, which also instructs the link-editor to build the global offset table.
