Solaris Advanced Installation Guide
SPARC: Example: Adding Systems to Be Installed Over the Network With add_install_client
The following example adds a system named basil, which is a SPARCstation 10, to be installed over the network. The system requires a boot server, so the command is run on the boot server; the -s option is used to specify the install server named install_server1, which contains a Solaris CD image in /export/install.
# cd /export/boot/Solaris_2.7/Tools
# ./add_install_client -s install_server1:/export/install basil sun4m
